internal memory
riggeek
internal memory
Post by riggeek »
Looking thou other people code for the Jeabo DC pump has lead me to a question.
If I use code like what is listed be low. Will I still be able to switch pump modes or will this hard lock the code to what is programmed? Would I need to used some sorta 1 shot to set the mode?
I would like to use short pulse pump mode in the day and constant at night with the refugium light being on as the trigger. As well as a nutrient transport mode after feeding.
part of Sacohen code
static unsigned long feeding;
if (now()-feeding<3600) {
// Continue NTM for the 60 minutes
ReefAngel.DCPump.Mode=NutrientTransport
} else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
// Night mode (go to 30%)
ReefAngel.DCPump.Mode=Constant;
ReefAngel.DCPump.Speed=30;
} else if (InternalMemory.DCPumpMode_read()==11) {
ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
} else {
thanks
riggeek
riggeek
Re: internal memory
In that code the night and feeding mode trump the portal but it only does the random mode per day when you've selected Custom mode.
riggeek
Re: internal memory
Post by riggeek »
So how would you go about setting the code, but not trumping if it is changed in the portal?
riggeek
riggeek
Re: internal memory
Thats how it is set...
