Used reef angel
sepulvd
Used reef angel
I just received a used reef angel but I can't figure out why every couple mins the relays are clicking on and off and why the status lights blinks red a bunch of time and the unit resets itself. Any help would be appreciated.
- Sacohen
Re: Used reef angel
Disconnect everything except the relay and see if that resolves the issue.
If it does connect the modules and probes 1 at a time until you determine which one is causing the problem.
sepulvd
Re: Used reef angel
Nothing is connected except the relay box and the screen to my computer
Re: Used reef angel
Do you have a USB power cable?
Try powering just the head unit.
If it doesn't work, look for signs of water damage.
sepulvd
Re: Used reef angel
Yes i powered tge head unit with the USB cable no restart
sepulvd
Re: Used reef angel
I think it's the cable from the head unit to the labtop only time it resets it self
pandimus
Re: Used reef angel
Could it be programmed with test mode by chance?
sepulvd
Re: Used reef angel
How do I check if it's in test mode. Sorry am a newbie to the reef angel. I set it to the preloaded script
- cosmith71
Re: Used reef angel
When you plug in the USB cable from the computer, make sure the black wire is all the way to the right (facing the head unit). You'll have an extra empty pin on the far left.
