RANet Ready Relay Box
Hey Guys,
Here is a video of the RANet module controlling a RANet ready relay box.
[youtube]http://www.youtube.com/watch?v=JMBARknej_Y[/youtube]
This relay box will be the first of the wireless expansion modules that will be available shortly.
Re: RANet Ready Relay Box
That's awesome!
Oh wow....am so loving the creativity from you guys.
Very Cool.
When you asked for suggestions in the other thread I was thinking of a wireless Relay or Power control module.
Very Nice. How far will the wireless reach? standard stuff? Kicking myself for wiring an extension plug to the pump in the basement.
That is awesome. How is the fallbacks set on the ports? Is it through software or jumpers?
Love it! Aesthetically it is very nice as well. Wireless reach info is important too and would love to know if putting a relay in my basement is okay.
Jack
One thing about zigbee is that devices are also repeaters if I'm not mistaken. Would we be able to talk to standard zigbee devices at all? And would other zigbee devices in the house help (if I'm correct on zigbee retransmission?) the RANet signals? If so then we'd definitely be able to extend to other areas as far as range. Hell, next device request - RANet repeater
As simple as this:lnevo wrote:That is awesome. How is the fallbacks set on the ports? Is it through software or jumpers?
ReefAngel.Relay.RANetFallBackE[0]=Port7Bit;
The manufacturer advertises 300ft, but that is usually open field range.Smotz wrote:Very Nice. How far will the wireless reach? standard stuff? Kicking myself for wiring an extension plug to the pump in the basement.
I have the return pump on port 5 and skimmer on port 1 on the wireless relay box. Recently the relay box has been losing connectivity from the RA controller on and off and this effectively stops the return pump and skimmer. Is there a way to have the 2 ports to be on even when the relay box loses connectivity from the RA controller?rimai wrote:As simple as this:lnevo wrote:That is awesome. How is the fallbacks set on the ports? Is it through software or jumpers?This line will turn port 7 on and all other ports off.Code: Select all
Dr Davaraj
ReefAngel.Relay.RANetFallBackE[0]=Port1Bit | Port5Bit;
Thanks Lee. I'll add that into my code.lnevo wrote:Code: Select all
are these available?
rimai wrote:I think I still have one left
Oi..Gonna hold out until they're officially released.
how do I get this to work? It's just flashing a white light at me...
#include <SoftwareSerial.h>
#define Heater 1
#define Return 2
#define HeaterTk2 3
#define Skimmer 4
#define Vortech1 5
#define Vortech2 6
#define ATO 7
#define Sump Light 8
byte vtechmode, vtSpeed, vtDuration;
ReefAngel.FeedingModePorts = Port2Bit;
// ReefAngel.FeedingModePortsE[0] = 0;
// ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit;
// ReefAngel.WaterChangePortsE[0] = 0;
// ReefAngel.LightsOnPorts = 0;
// ReefAngel.LightsOnPortsE[0] = 0;
// ReefAngel.OverheatShutoffPortsE[0] = 0;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
// Hardcode calibrations
ReefAngel.PHMin=576; // PH7.0
ReefAngel.PHMax=842; // PH10.0
ReefAngel.SalMax=3300; // 35ppt
vtechmode=InternalMemory.RFMode_read();
vtSpeed=InternalMemory.RFSpeed_read();
vtDuration=InternalMemory.RFDuration_read();
static unsigned long feeding;
ReefAngel.StandardHeater( Port1,778,782 );
ReefAngel.WaterLevelATO( Port7,180,71,74 );
ReefAngel.StandardLights( Port8,15,0,2,0 );
ReefAngel.PWM.SetChannel( 0,PWMSlope(19,00,21,00,15,51,20,0) ); //MOON
ReefAngel.PWM.SetChannel( 1,PWMSlope(12,30,20,00,15,50,30,0) ); //RB
ReefAngel.PWM.SetChannel( 2,PWMSlope(12,20,20,00,15,95,30,0) ); //WHITE
ReefAngel.PWM.SetChannel( 3,PWMSlope(12,15,20,00,15,70,30,0) ); //BLUE&CYAN
ReefAngel.PWM.SetChannel( 4,PWMSlope(12,00,20,30,15,70,30,0) ); //UV
if ( ReefAngel.HighATO.IsActive())
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.Off(Port2);
if (hour() >=13 && hour() < 20)
// if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0);
ReefAngel.RF.UseMemory=true;
// ReefAngel.RF.SetMode(ReefCrest,60,20);
feeding=now();
if (now()-feeding<5400) {
// if (now()-feeding > 1 && now()-feeding < 5400) { // 1 second after feeding mode until 60 minutes after feeding mode.
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(Smart_NTM,75,10);
ReefAngel.RF.SetMode(Constant,10,0);
if (vtechmode!=InternalMemory.RFMode_read())
InternalMemory.RFMode_write(vtechmode);
if (vtSpeed!=InternalMemory.RFSpeed_read())
InternalMemory.RFSpeed_write(vtSpeed);
if (vtDuration!=InternalMemory.RFDuration_read())
InternalMemory.RFDuration_write(vtDuration);
ReefAngel.Portal( "bencollinz" );
char text[7];
ReefAngel.LCD.DrawDate( 6, 2 );
ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
else if (vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
ReefAngel.LCD.DrawText(0,255,4,30,"RF Speed:");
ReefAngel.LCD.Clear(255,59,29,128,39);
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,71,31,vtSpeed);
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,90,31,"/");
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,100,31,vtDuration);
ReefAngel.LCD.DrawText(0,255,10,40,"Salt");
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 50, text, Num8x8);
/* ReefAngel.LCD.DrawText(0,255,50,40,"Fresh");
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 50, 50, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,100,40,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 50, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,13,58,"Salinity");
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 13, 68, text, Num8x8);
// water level
ReefAngel.LCD.DrawText(0,255,68,58,"WL");
ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 68, 68, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawOutletBox( 12, 108, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 120, TempRelay );
/* void Heater2(byte HeaterRelay, int LowTemp, int HighTemp)
if (ReefAngel.Params.Temp[T2_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
void Heater1(byte HeaterRelay, int LowTemp, int HighTemp)
if (ReefAngel.Params.Temp[T1_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T1_PROBE] <= LowTemp && ReefAngel.Params.Temp[T1_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T1_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
Roberto, what is the availability of the wireless relay box?rimai wrote:Hey Guys,
