Avast ATO and RA+
Squishie89
Avast ATO and RA+
I upgraded my head unit to the RA+ and it was either then or shortly after my avast ato stopped working. Is there anything in the new libraries that could be doing this or did my ato just die for some reason? (Pump still works, but nothing will make the trigger unit trigger).
Re: Avast ATO and RA+
Isn't Avast ATO a standalone?
Or you have their controllable with the adapter cable?
Squishie89
Controllable with the adapter cable.
Squishie89
I have no idea how to do that, sorry =X Can you explain or point me towards a thread?
File->Sketchbook->Example Codes->ControllerTester
Upload and test the ports.
Squishie89
So I uploaded the code. ATO showed high and low as OPEN. I pulled the ATO probe thing out of the water and it still showed as open. So I am thinking I need to buy a new ATO.
Just to confirm, before you go buying anything...
Can you unplug the avast ato connector from RA and use a regular float switch?
Squishie89
I assume you were concerned it might be the head unit? I got out my original float switches and plugged them in and it all worked fine. So it seems it is something with the Avast unit or plug.
Squishie89
I got my new ATO switch from AVAST. However I still cannot get it to trigger! Here is a copy of my code, please let me know if you see anything wrong here. I am going to run another controller test to double check things. (I am not too great with the coding yet so something might be wrong that I never noticed)
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.StandardLights( Port1,13,30,22,30 ); //set for actinic
ReefAngel.SingleATO( false,Port2,900,0 ); //15 min time out
ReefAngel.StandardLights( Port4,14,0,22,0 ); //set for white light
//removed wavemaker functions because I don't want them turning off
ReefAngel.StandardHeater( Port7,775,780 );
ReefAngel.PWM.SetDaylight( PWMSlope(13,30,22,0,15,100,30,15) );
//ReefAngel.PWM.SetActinic( PWMParabola(13,0,22,30,15,100,15) );
// prevent auto top off from 2200 to 1200
if (hour()>12 && hour()<22)
ReefAngel.SingleATO( false,Port2,600,0 );
ReefAngel.Relay.Off( Port2 );
// Skimmer delay after feed or wc, 60 minutes
ReefAngel.Relay.DelayedOn( Port3,60 );
ReefAngel.Portal( "Squishie89" );
int x,y;
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,54, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,54, ReefAngel.Params.Salinity );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,75, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,75, ReefAngel.Params.PHExp );
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,75, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,75, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
// Date and Time
}Re: Avast ATO and RA+
Just to confirm, your ATO is disabled from 10pm to noon, right?
What time did you perform your test?
Squishie89
I did FINALLY figure out how to make the ATO work. However, now I cannot get my time out to work. Here is my updated code (sorry for all the notes, and the code that is //-ed out above the ATO coding is what I had before, kept it to copy it). I am wondering if the time out needs to be in the custom code in the void loop? Not sure.
//if (hour()>12 && hour()<22)
//ReefAngel.SingleATO( false,Port2,600,0 );
//else
//ReefAngel.Relay.Off( Port2 );
ReefAngel.SingleATOLow( Port2 );
// Skimmer delay after feed or wc, 30 minutes
ReefAngel.Relay.DelayedOn( Port3,30 );
int x,y;
// Parameters
// Salinity
// pH Expansion
// Water Level
// Main Relay Box
// Date and Time
Code looks ok, except for this line:
Technically, it will only run from 1 PM to 9 PM.
Run the controller test again. If you can't get it to change state, then there's an issue with the topoff unit. Since you've replaced the switch, I'd suspect the cable. Check the pins on the cable and make sure they're seated properly. If you have a voltmeter you might check continuity in the wires.
Squishie89
That is supposed to be there. My tank is near my birds and they don't get woken up till noon/1pm and I don't want the top off pump bothering them while they are sleeping.cosmith71 wrote:Code looks ok, except for this line:
Technically, it will only run from 1 PM to 9 PM.Code: Select all
I will check the cable, thanks so much, Colin!
howaboutme
I have an Avast ATO. If the ATO runs then the issue regarding timeout is not the ATO, most likely code related.
My code for the Avast uses internal memory and is every simple:
I control the timeout from the portal.
ReefAngel.SingleATOLow( Port1) Jack
OK, so when I replied, I somehow missed all of page 2, and missed that you'd fixed it and moved on to another problem.
So now, it won't time out? Like Roberto said, check the internal memory setting. You can do that from the Portal.
Squishie89
It does time out, the problem is I thought I set the time out for 15 minutes, it times out in 5 min or less
Check in the portal under internal memory settings. You have 15 minutes specified in your code but the last iteration uses memory which we cant see how yours is set.
Squishie89
I was able to get into the internal memory settings through the portal, currently trying to get it to save.
I don't understand what in my code makes it use the internal memory, I would prefer to keep everything in the code and not use the portal.
This line makes it use memory:Squishie89 wrote:I was able to get into the internal memory settings through the portal, currently trying to get it to save.
