lights not coming on
jjdezek
Post by jjdezek »
i set up my new light dimming module and the lights arnt coming on. i have anolog controllers and plugged all the bus connectors on the left side. here is my current code.
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <ReefAngel.h>
#define NUMBERS_8x16
// the graph is drawn/updated when we exit the main menu &
// when the parameters are saved
ReefAngel.LCD.DrawText(COLOR_INDIGO, COLOR_WHITE,25,5, "Jeremy's Reef");
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
    ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.StandardATO( Port1,20 );
    ReefAngel.StandardLights( Port3,18,0,10,0 );
    ReefAngel.StandardHeater( Port7);
    ReefAngel.PWM.SetChannel( 0, PWMSlope(7,0,21,0,10,55,180,10) );
    ReefAngel.PWM.SetChannel( 1, PWMSlope(7,5,21,5,10,45,180,10) );
    ReefAngel.PWM.SetChannel( 2, PWMSlope(7,10,21,10,10,55,180,10) );
    ReefAngel.PWM.SetChannel( 3, PWMSlope(7,15,21,15,10,45,180,10) );
    ReefAngel.PWM.SetChannel( 4, PWMSlope(7,20,21,20,10,55,180,10) );
    ReefAngel.DCPump.DaylightChannel = AntiSync;
      if (ReefAngel.DCPump.Mode==Custom)
  ReefAngel.PWM.SetDaylight( ElseMode(70,30,true )); // ElseMode on sync mode, 70 +/- 30%
  ReefAngel.PWM.SetActinic( ElseMode(70,30,false )); // ElseMode on anti-sync mode, 70 +/- 30%
    ReefAngel.Portal( "jjdezek" );
void DrawParamsa(int x, int y){
char buf[16];
  ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x+70,y+10,"WP40L:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+108, y+10,1);
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+70,y+20,"WP40R:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+108, y+20,1);
void DrawParams(int x, int y) {
  char buf[16];
  // Temp and PH
  y+=10;
    ConvertNumToString(buf, ReefAngel.Params.Temp[T2_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(T2TempColor, DefaultBGColor, x+5, y+12, buf, Num8x16);
    ConvertNumToString(buf, ReefAngel.Params.Temp[T3_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(T3TempColor, DefaultBGColor, x+40, y+12, buf, Num8x16);
  y+=5;
   ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,10,18, "SAL:" );
    ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.Salinity,COLOR_DARKKHAKI,33,18, 10 );
void DrawStatus(int x, int y) {
  int t=x;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"High",Font8x16);
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,y,"Low",Font8x16);
  } else {
  } else {
      NewSpeed = MidPoint - ChangeUp;
      AntiSpeed = MidPoint + ChangeUp;
      NewSpeed = MidPoint + ChangeUp;
      AntiSpeed = MidPoint - ChangeUp;
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
Re: lights not coming on
Can you open the module and check a lone jumper?
It must be off.
There were a few modules that were shipped with that jumper on.
jjdezek
Post by jjdezek »
the one off to the right side of the pwm prongs?
jjdezek
Post by jjdezek »
that was the ticket. thanks
jjdezek
Post by jjdezek »
Well I thought that was a fix. My lights were on but now there not turning off. Am I missing part of the code that says when they should come on and when they should turn off?
Looks like they start dimming around 9 PM. They only dim down to 10%, though.
jjdezek
Post by jjdezek »
They were still pretty bright this morning and I believe my drivers don't kick on until 10. Maybe I need to change it to 8 or 9
I'd start at 0 to test.
What kind of drivers?
jjdezek
Post by jjdezek »
ELN-60d-48
