Reef Angel Android App Dimming error
paperdesk
Post by paperdesk »
I've recently installed a dimming module, and I find that I'm getting errors when I try to change the dimming values using the Reef Angel Android App.
Sometimes it works, sometimes it doesn't. I haven't nailed it down for sure, but it may only be when I try to set a channel to less than 10%.
Errors I've gotten are:
Error 13: Device Authentication Error
Error 24: XML Read Exception
Error 13: Connection Reset by Peer
Error 23: At line 1, column 518: unclosed token
Is this perhaps a coding issue not an app issue?
Re: Reef Angel Android App Dimming error
I have the same problem on an old android phone I have.
Did you try with another phone?
I get this from time to time from the controller. I'm wondering if it has to do with the amount of data sent from the controller but I have not pinpointed the error yet.
Sent from my Moto X
paperdesk
Post by paperdesk »
I'm using a Samsung Galaxy Nexus. I will try with my S4.
