how to code jebao
Ademster
how to code jebao
Post by Ademster »
this is the code I am using from a member here on the board.
I want it to be random through out the day,
not just at midnight it changes or upon reboot.
     static int rmode;
    byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else, Gyre };
    if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
    rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
    changeMode=false;
    static unsigned long feeding;
    if (now()-feeding<3600) {
    // Continue NTM for the 60 minutes
    ReefAngel.DCPump.Mode=NutrientTransport;
    } else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
    // Night mode (go to 30%)
    ReefAngel.DCPump.Mode=Constant;
    ReefAngel.DCPump.Speed=30;
    } else if (InternalMemory.DCPumpMode_read()==11) {
    ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
    } else {
Adam
58 Gal
Re: how to code jebao
Change SECS_PER_DAY to whatever time in seconds you want it to switch modes
Ademster
Post by Ademster »
awesome thanks greatly appreciated
Adam
58 Gal
