jebao cables w/ w25 pump
Civics14
Hi all,
Do I need to power this from the RA+ relay box when I have it controlled with the Jebao cable attachment? Or can it be plugged into my power station?
Thank you
Thank you
pandimus
Re: jebao cables w/ w25 pump
What's a power station?
pandimus
It has to be plugged into the relay, and you have to use the power cable that came with your jebao
It can be plugged into a non RA relay if you want to save ports. I think it would draw too many amps for the power station.
Pandimus, the power station is a relay box with 12V dc out instead of 110 ac
pandimus
I figured that is what he meant.. But I thought it was called power control... Isn't the jebao power supplies 48v?
pandimus
Civics14
pandimus
That's exactly how I do it.. But I call it a day strip...Civics14 wrote:American DJ PC-100apandimus wrote:What's a power station?
No, there's a reef angel power station module that is a relay box but for 12vdc devices.
- cosmith71
The answer to the original question is you can plug the Jebao power supply into any AC outlet. Doesn't have to be the relay box.
Civics14
Thank you Colincosmith71 wrote:The answer to the original question is you can plug the Jebao power supply into any AC outlet. Doesn't have to be the relay box.![]()
