jebao cables w/ w25 pump
Civics14
Post by Civics14 »
Hi all,
Do I need to power this from the RA+ relay box when I have it controlled with the Jebao cable attachment? Or can it be plugged into my power station?
Thank you
pandimus
Re: jebao cables w/ w25 pump
Post by pandimus »
What's a power station?
pandimus
Post by pandimus »
It has to be plugged into the relay, and you have to use the power cable that came with your jebao
It can be plugged into a non RA relay if you want to save ports. I think it would draw too many amps for the power station.
Pandimus, the power station is a relay box with 12V dc out instead of 110 ac
pandimus
Post by pandimus »
I figured that is what he meant.. But I thought it was called power control... Isn't the jebao power supplies 48v?
pandimus
Post by pandimus »
Error 24v
Civics14
Post by Civics14 »
pandimus wrote:What's a power station?
American DJ PC-100a
pandimus
Post by pandimus »
American DJ PC-100a
That's exactly how I do it.. But I call it a day strip...
No, there's a reef angel power station module that is a relay box but for 12vdc devices.
The answer to the original question is you can plug the Jebao power supply into any AC outlet. Doesn't have to be the relay box. :geek:
Civics14
Post by Civics14 »
cosmith71 wrote:The answer to the original question is you can plug the Jebao power supply into any AC outlet. Doesn't have to be the relay box. :geek:
Thank you Colin
