wavemaker random option
Reefology
Hi,
when i originally set up/tested the wizard, random option in wavemaker was available but just now the wizard won't allow me to select it?! Can someone explain why and help me fix it?
Re: wavemaker random option
You can use that on port 5 and 6
Sent from my Galaxy S5 with Tapatalk
Ademster
reefology is right, the option is no longer available to use on the wizard.
Adam
58 Gal
58 Gal
Reefology
Reefology
ok, if i go back in wizard and i select "in the code" in memory settings, it allows me to select the random option. If I select "in the internal memory" i can only select constant and all wavemaker ports have to be on at the same time. I presume it would require custom code which is not something I really want to take on at this point.
- cosmith71
You can run the wizard and have it generate the code you want and cut and paste into your core code.
I ran the wizard with no options except the wavemakers (in the code). It gave me this:
These two lines are what you want:
Just copy and paste these two lines into your loop() and you have random wavemakers.
The 60 and 100 are the lower and upper limits of the random times. Change them to whatever you want.
Voila. You have your first custom code.
ReefAngel.WavemakerRandom( Port5,60,100 );
ReefAngel.WavemakerRandom( Port6,60,100 );
ReefAngel.WavemakerRandom( Port6,60,100 );The 60 and 100 are the lower and upper limits of the random times. Change them to whatever you want.
Reefology
Thanks Colin, copied and pasted!
So in the future if I update some parameters in the internal memory (say my lighting schedule), in either the portal or the iphone app, does this also effect the wavemaker? With this code I don't get the random option to adjust in the internal memory.
- cosmith71
Nope. The wavemakers are under control of the above code. I don't think there are memory locations for the random function and that is why it must be hard coded.
When you update memory values for one thing, that's the only thing affected.
In fact, if you have something hard coded (like a lighting schedule) you can change the memory values all day and it won't make any difference.
Reefology
well i tested it and i get a wavemaker error message under the internal memory in the portal, and as a result, port 6 has been inactive throughout the night.
I'm guessing when it comes to the internal memory, its all or nothing (seeing there's a single save button for all parameters)? it would be cool if you could save each function independently.
Thanks Colin...I'm saying that a lot recently
- cosmith71
Are you using the above code? Internal memory will not affect it, since it's hard coded.
- cosmith71
Oh, and you're welcome. I've had 5 days off and I've had a lot of computer time.
Reefology
lol, I've had a lot of computer time as well over the holidays...trying to squeeze a little more in before i head out to work
Nothinng in your code so long as port forwarding is set right should give you an error from the portal. If you had all hard coded you could still use the portal to preset all the memory locations. Can you screenshot the error?
Reefology
now i got this error msg trying to upload the screenshot.
Screenshot from 2015-01-05 17:19:22.png is an invalid filename.
Reefology
did this work?
Ok so your port forwarding is good but I think your confused about wavemaker and dcpump. Not sure why you got that error, but Wavemaker means you are using relay port 5 and 6 with simple on/off powerheads. The DCPump is used to control Jaebo style controllable pumps. So which are you using? If you have the jaebo pumps they don't have to use up a port on your relay bar and you don't want to be doing the wavemaker functions with them.
And now that your banner is working i can see you have one jaebo and one koralia.
Could you start a thread and post your current code that your using? We can keep all the questions related to your setup in one place
Reefology
