Reefology's code
Reefology
Reefology's code
Post by Reefology »
Current code
void SeasonalTemps ()
  static int heatArray[][2] = { {778,784},// default in case of error in month=0 (May)
                    {762,768},//January (winter)
                    {766,772},//February (winter)
                    {770,776},//March (early spring)
                    {774,780},//April (spring)
                    {778,784},//May (spring)
                    {782,788},//June (early summer)
                    {786,792},//July (summer)
                    {782,788},//August (summer)
                    {778,784},//September (early fall)
                    {772,780},//October (fall)
                    {770,776},//November (fall)
                    {766,772} };//December (early winter)
  ReefAngel.StandardHeater( Port1,heatArray[month()][0],heatArray[month()][1]);
 }//end seasonalTemps
    ReefAngel.FeedingModePorts = Port3Bit | Port5Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit;
    //Feeding Timer
    ReefAngel.Timer[FEEDING_TIMER].SetInterval(2100);
    SeasonalTemps();
    ReefAngel.ActinicLights( Port2 ); // Royal blue led strip
    ReefAngel.DayLights( Port4 ); // T5's
    ReefAngel.StandardFan( Port6 );
    // koralia 1150
    // if (hour()>=23 || hour()<11) ReefAngel.Relay.Off( Port5 );
    // else ReefAngel.WavemakerRandom( Port5, 120, 1800 );
    //ATO
    //if ((hour()>=20 || hour()<=8) && (ReefAngel.Params.PH < 830))
    // ReefAngel.SingleATO(false,Port5,180,0);   //  Sump switch. Kalk schedule 8pm - 8am if pH < 8.3  If ATO/Kalk runs for 180 seconds, shut off and send alert.
    // else
    // ReefAngel.SingleATO(false,Port8,180,0);   //  Sump switch.  If ATO/RoDi runs for 180 seconds, shut off and send alert.
    //skimmer off when collection container is full
    if (ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port3);
    else ReefAngel.StandardLights( Port3, 17,0,9,0); //skimmer off 9am-5pm
    //light mover
    //if (hour()>=9 && hour()<=21) ReefAngel.DosingPumpRepeat( Port6,0,90,2 );   //  from 9am - 9pm, moves 2 seconds every 90 minutes with 0 minutes offset
    //else ReefAngel.Relay.Off( Port6);
    //kalk dosing
    if ((hour()>13 && hour()<20) || (ReefAngel.Params.PH > 845))
    ReefAngel.Relay.Off( Port7); //  Kalk off 1pm - 8pm & if pH is > 8.45
    ReefAngel.PHControl( Port7 );
   //carbon dosing
    if (hour()>=6 && hour()<23) ReefAngel.DosingPumpRepeat1( Port8 );
    else ReefAngel.Relay.Off( Port8);
    ReefAngel.Portal( "reefology" );
Original Post
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.DDNS( "" );
    ReefAngel.DosingPumpRepeat1( Port1 );
    ReefAngel.MoonLights( Port2 );
    ReefAngel.ActinicLights( Port3 );
    ReefAngel.WavemakerRandom( Port5,119,1200 );
    ReefAngel.WavemakerRandom( Port6,99,1000 );
    ReefAngel.Portal( "" );
    ReefAngel.DDNS( "" ); // Your DDNS is
Reefology
Re: My code
Post by Reefology »
so should i take the jebao port offline? well it isn't working anyway :D
Re: My code
Just set it to always on, or plug it into a power strip. Let the stock Jebao controller handle the pump, unless you want to use a Jebao cable to control it with the RA.
You also need to remove this line:
ReefAngel.DDNS( "Reefology" ); // Your DDNS is Reefology-tank.myreefangel.com
You already have a DDNS declaration in setup(). That's probably why you're having issues with your phone app.
Reefology
Re: My code
Post by Reefology »
great Colin, will do. But you might want to note that i didnt manually add it, was done by the wizard.
I also wanted to add password authentication but havent' figured out how, can you help me with that? I'm aware i won't be able to use the iphone app until its supported.
thanks
Re: My code
Must have been an evil Wizard. Voldemort is my guess. ;)
I don't use the password authentication. Maybe someone else can chime in. I do know you won't be able to use the iPhone app if you enable it.
Re: Reefology's code
Add this in setup
ReefAngel.Network.WifiAuthentication("username:password");
Change username and password for whatever you'd like it to be.
Reefology
Post by Reefology »
great thanks, i forgot Roberto had already given it to me just couldn't find it.
Reefology
Post by Reefology »
Added this custom code that i copied from anothher user but not getting desired result. Can someone explain each section so i can learn the code and make adjustments going forward please?
FYI, i changed ''if (now()%SECS_PER_DAY==600'' from 0 to 600 hoping to change mode every 10 mins.
static int rmode;
    byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre };
    if (now()%SECS_PER_DAY==600 || changeMode==true) { // Change every 10 mins or if controller rebooted
    rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
    changeMode=false;
    static unsigned long feeding;
    if (now()-feeding<3600) {
    // Continue NTM for the 60 minutes
    ReefAngel.DCPump.Mode=NutrientTransport;
    } else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
    // Night mode (go to 30%)
    ReefAngel.DCPump.Mode=Sine;
    ReefAngel.DCPump.Speed=30;
    } else if (InternalMemory.DCPumpMode_read()==11) {
    ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
    } else {
What desired behavior are you trying to get and what behavior are you seeing instead..
Reefology
Post by Reefology »
thanks for the quick response. I have a single WP40 and would like to have alternate wave modes that change throughout each day, I'd like a calm mode at night running at 30% or less if possible (but not sure it is), I'd like to override via internal memory if possible and then have it revert back to random after a set time (but not a must have).
I like the way it kicks into night mode and feed mode but it doesnt alternate wave patterns listed in the code its stuck in else mode.
I think it's this line here.
This tells it to change modes every 24 hours and 10 minutes.
Try changing it to this.
if (now()%600==0 || changeMode==true) {
Edit: Forgot the {
Reefology
Post by Reefology »
thanks so much, will try that. while we're at it, is there anyway to make the speed random? I assume some of the modes have random speed built in but i dont know which ones so I just selected all of them hoping to get a varying flow.
Thnaks
Here's some commented code. You will also find this link handy:
http://arduino.cc/en/Reference/HomePage
Look up the different kinds of data types (int, boolean, unsigned long) and also if...else. Also read up on arithmetic, boolean, and comparison operators.
// Declare an integer (a whole number between -32,768 to 32,767) rmode
// and a boolean (false or true, 0 or 1) changeMode which is set to true.
// "static" means only initialize them once.  Otherwise they would be reset
// every time loop loops around.
static int rmode;
// modes[] is an array of bytes (whole numbers between 0 and 255).
byte modes[] = {
// now() is a running tally of seconds since Jan 1, 1970.  It's a big number.
// % is modulo, it returns the remainder from division.  So, if the number of seconds ever
// divided by 600 is 0 (that is, every 600 seconds or 10 minutes) then this is true.
// The || means 'or'.  '==' means 'is equal to'.  So this line says 'if it's been 10 minutes,
// or changeMode is equal to true, then do this stuff in these curly braces.
if (now()%600==0 || changeMode==true) { // Change every 10 mins or if controller rebooted
  changeMode=false;
static unsigned long feeding;  // another variable declaration, type unsigned long
// Difference between '==' and '=':  '==' means 'is equal to' (comparing two things)
// '=' means 'make equal to' as in changing the value of something.  So this line
// says if the menu displayed is equal to FEEDING_MODE, then make the variable 'feeding'
// equal to the number of seconds returned by the function now()
// if right now minus the time feeding was set is less than 3600 (seconds, remember now() returns
// seconds) then do the stuff in the curly braces.
  ReefAngel.DCPump.UseMemory=false;  // Turn off portal control of the pumps
  ReefAngel.DCPump.Duration=InternalMemory.DCPumpDuration_read();  // Get the portal pump duration from memory
  ReefAngel.DCPump.Mode=NutrientTransport;    // Manually set the mode to NutrientTransport
// so if the above 'if' isn't true, do the stuff after 'else'.  If this thing is true, do this stuff, else do other stuff
// If it's been more than 60 minutes since feeding time, check to see if now (in seconds) divided by
// the number of seconds per day (86400 to be exact) returns a remainder of less than 43200 (noon)
// or greater than 79200 (10 PM, 2200) then do some stuff
  ReefAngel.DCPump.UseMemory=false;  // Turn off portal control of DC Pumps
  ReefAngel.DCPump.Duration=InternalMemory.DCPumpDuration_read();  // Get portal duration from memory location
  ReefAngel.DCPump.Mode=Sine;  // Set the mode to Sine
  ReefAngel.DCPump.Speed=30;   // With a speed of 30
// if the above isn't true, check this
  // Custom Mode set on portal and nothing else going on (not feeding time, not night time)
  ReefAngel.DCPump.UseMemory=false;  // Turn off portal control of pumps
  ReefAngel.DCPump.Duration=InternalMemory.DCPumpDuration_read();  // Get the duration
// if none of this stuff was true, default to this
else {
  // Do whatever the portal says to do with the DC Pumps
You mean the speed at which the pumps run? Some modes like Else do that automatically. Others, like gyre and sine, go up and down in a set pattern.
Reefology
Post by Reefology »
awesome thank you, the notes are a huge help to me. I'll check out the link as well.
cheers
Reefology
Post by Reefology »
its still stuck in else mode and doesnt change?!
Do you have the portal set to custom?
Reefology
Post by Reefology »
not sure, here is all my code:
    ReefAngel.FeedingModePorts = Port6Bit;
    ReefAngel.WaterChangePorts = Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    // Password Protection username:xxxxxxx password:xxxxxxx
    // ReefAngel.Network.WifiAuthentication("xxxxxx,xxxxxxx");
    ReefAngel.DosingPumpRepeat2( Port2 );
    ReefAngel.MoonLights( Port5 );
    ReefAngel.WavemakerRandom( Port6,120,1500 );
    static int rmode;
    changeMode=false;
    } else {
    ReefAngel.Portal( "Reefology" );
    ReefAngel.DDNS( "xxxxxxxx" ); // Your DDNS is Reefology-xxxxxxxx.myreefangel.com
Reefology
Post by Reefology »
ok found custom in the portal. but now im wondering what the speed and duration does? doesnt ''custom'' call the code in the custom area thereby overriding speed and duration? asking because now that ive managed to get the modes to changing every 10 minutes, the speed stays the same?
Speed and duration are pulled from the portal. The speed will report in that section as static but you should see the speed change on the screen.
Reefology
Post by Reefology »
this is awesome, im in love with my reef angel and what it is capable of...
now that i have my dc pump up and running, I'm going back to something i put on hold, can someone please look at the code i just put up and tell me why i still cant log into the iphone app using my DDNS?
Make sure you enter reefology-ddns.myreefangel.com
Change the ddns to whatever you choose. Make sure it is - and not _
Reefology
Post by Reefology »
Thanks Roberto but I've checked it too many times to count. Are there other possibilities?
PM me what you are entering. I checked the server and the entries are all there.
I saw 3 entries for you, but they were all same ip address.
Reefology
Post by Reefology »
pm sent
Reefology
Post by Reefology »
current code
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit;
    // Password Protection username:xxxx password:xxxx
    // ReefAngel.Network.WifiAuthentication("xxxx");
    ReefAngel.WavemakerRandom1( Port5,120,1500 );
    ReefAngel.WavemakerRandom2( Port6,180,1000 );
    ReefAngel.DosingPumpRepeat2( Port8 );
    ReefAngel.DCPump.ActinicChannel = AntiSync; // Now pump will be affected by the portal settings
    // Comment out next 2 lines for single dc pump
    // ReefAngel.DCPump.DaylightChannel = Sync; // Now pump will be affected by the portal settings
    // ReefAngel.DCPump.AntiSyncOffset=100;
  // Wavemaker Koralia night mode
    if (hour()>=22 || hour()<7) ReefAngel.Relay.Off (Port5 );
    if (hour()>=23 || hour()<8) ReefAngel.Relay.Off (Port6 );
  // DC pumps
    // To run this code must choose Custom in portal
    static int rmode;
    byte modes[] = { NutrientTransport, Sine, ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
    if (now()%1200==0 || changeMode==true) { // Change every 20 (1200seconds) mins or controller reboot
    rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
    changeMode=false;
    if (now()-feeding<3000) {
    // Continue NutrientTranspot Mode for 45 minutes
    } else if (now()%SECS_PER_DAY<37800 || now()%SECS_PER_DAY>=81000) { // 10:30am / 10:30pm
    ReefAngel.DCPump.Mode=Gyre;
    } else {
    ReefAngel.DDNS("xxxx"); // Your DDNS is Reefology-xxxx.myreefangel.com
Have another dc pump coming and just want to makes sure i'm ready with code.
Reefology
Post by Reefology »
do i just change this?
Reefology
Post by Reefology »
and does the antisync offset delay 2nd pump by 100 seconds?
No, it allows the antisync channel to be 100% of what it should be. If you have a strong or weaker pump, you could adjust that pump to compensate.
Reefology
Post by Reefology »
sorry, i don't understand.
so if i have a Jebao wp40 and a wp25, how would i use the offset?
