no internal memory
hawaiiensis38
no internal memory
hello
someone can help me?
i got the RA that show no internal memory
i upload the file correcly the file but, still the same error.
i read some topic about this error and found this one
the seems to be the same thing like mine, the log too
- http://forum.reefangel.com/viewtopic.ph ... und#p36316
i read this one but i don't understand how i can used the file
- http://forum.reefangel.com/viewtopic.php?f=15&t=4085
someone can tell me step by step how to do
merci
olivier
merci
olivier
hawaiiensis38
Re: no internal memory
the libraries version is : 1.1.1
olivier
olivier
Add this right before ReefAngel.Init() to your code:
Upload the code again.
InternalMemory.IMCheck_write(0xCF06A31E);
hawaiiensis38
hello rimai
How can i do this, just on the open window when i open the Ardino?
can i dot that without connecting the ph and temp prob on the RA?
thanks
olivier
thanks
olivier
hawaiiensis38
Hello rimai
i make what you told me
but, it still the same No Internal memory Found
here the log:
i have it since one year but never exploited them so, I'm disappointed
regards
olivier
here the log:
I don't now what to do now, except to throw away the RA#include <ReefAngel_Features.h>
ReefAngel.Init();
InternalMemory.MHOnHour_write(15);
InternalMemory.MHOnMinute_write(30);
InternalMemory.MHOffHour_write(21);
InternalMemory.MHDelay_write(7);
InternalMemory.StdLightsOnHour_write(14);
InternalMemory.StdLightsOffHour_write(21);
InternalMemory.StdLightsOffMinute_write(30);
InternalMemory.DP1Timer_write(4);
InternalMemory.DP2Timer_write(4);
InternalMemory.LEDPWMActinic_write(20);
InternalMemory.LEDPWMDaylight_write(20);
InternalMemory.WM1Timer_write(10);
InternalMemory.WM2Timer_write(15);
InternalMemory.HeaterTempOn_write(766);
InternalMemory.HeaterTempOff_write(770);
InternalMemory.ChillerTempOn_write(774);
InternalMemory.ChillerTempOff_write(770);
InternalMemory.PHMax_write(830);
InternalMemory.PHMin_write(540);
InternalMemory.ORPMax_write(285);
InternalMemory.ORPMin_write(1400);
InternalMemory.RFMode_write(Constant);
InternalMemory.RFSpeed_write(50);
InternalMemory.RFDuration_write(8);
InternalMemory.PWMSlopeStartD_write(15);
InternalMemory.PWMSlopeEndD_write(100);
InternalMemory.PWMSlopeDurationD_write(60);
InternalMemory.PWMSlopeStartA_write(15);
InternalMemory.PWMSlopeEndA_write(100);
InternalMemory.PWMSlopeStart0_write(15);
InternalMemory.PWMSlopeEnd0_write(100);
InternalMemory.PWMSlopeDuration0_write(60);
InternalMemory.PWMSlopeStart1_write(15);
InternalMemory.PWMSlopeEnd1_write(100);
InternalMemory.PWMSlopeDuration1_write(60);
InternalMemory.PWMSlopeStart2_write(15);
InternalMemory.PWMSlopeEnd2_write(100);
InternalMemory.PWMSlopeDuration2_write(60);
InternalMemory.PWMSlopeStart3_write(15);
InternalMemory.PWMSlopeEnd3_write(100);
InternalMemory.PWMSlopeDuration3_write(60);
InternalMemory.PWMSlopeStart4_write(15);
InternalMemory.PWMSlopeEnd4_write(100);
InternalMemory.PWMSlopeDuration4_write(60);
InternalMemory.PWMSlopeStart5_write(15);
InternalMemory.PWMSlopeEnd5_write(100);
InternalMemory.PWMSlopeDuration5_write(60);
InternalMemory.ATOExtendedTimeout_write(120);
InternalMemory.ORPMin_write(2050);
InternalMemory.ORPMax_write(450);
InternalMemory.ActinicOffset_write(30);
InternalMemory.CO2ControlOn_write(770);
InternalMemory.CO2ControlOff_write(760);
InternalMemory.PHControlOn_write(800);
InternalMemory.PHControlOff_write(810);
InternalMemory.AISlopeStartW_write(0);
InternalMemory.AISlopeEndW_write(100);
InternalMemory.AISlopeDurationW_write(60);
InternalMemory.AISlopeStartB_write(0);
InternalMemory.AISlopeEndB_write(100);
InternalMemory.AISlopeDurationB_write(60);
InternalMemory.AISlopeStartRB_write(0);
InternalMemory.AISlopeEndRB_write(100);
InternalMemory.AISlopeDurationRB_write(60);
InternalMemory.RadionSlopeStartW_write(0);
InternalMemory.RadionSlopeEndW_write(100);
InternalMemory.RadionSlopeDurationW_write(60);
InternalMemory.RadionSlopeStartRB_write(0);
InternalMemory.RadionSlopeEndRB_write(100);
InternalMemory.RadionSlopeDurationRB_write(60);
InternalMemory.RadionSlopeStartR_write(0);
InternalMemory.RadionSlopeEndR_write(100);
InternalMemory.RadionSlopeDurationR_write(60);
InternalMemory.RadionSlopeStartG_write(0);
InternalMemory.RadionSlopeEndG_write(100);
InternalMemory.RadionSlopeDurationG_write(60);
InternalMemory.RadionSlopeStartB_write(0);
InternalMemory.RadionSlopeEndB_write(100);
InternalMemory.RadionSlopeDurationB_write(60);
InternalMemory.RadionSlopeStartI_write(0);
InternalMemory.RadionSlopeEndI_write(100);
InternalMemory.RadionSlopeDurationI_write(60);
InternalMemory.DelayedStart_write(7);
InternalMemory.PHExpMax_write(2500);
InternalMemory.PHExpMin_write(500);
InternalMemory.WaterLevelMax_write(3575);
InternalMemory.WaterLevelMin_write(2875);
InternalMemory.SalTempComp_write(750);
InternalMemory.WaterLevelLow_write(60);
InternalMemory.WaterLevelHigh_write(65);
InternalMemory.DP3Timer_write(4);
InternalMemory.DP3RepeatInterval_write(60);
InternalMemory.DCPumpMode_write(0);
InternalMemory.DCPumpSpeed_write(50);
InternalMemory.DCPumpDuration_write(50);
InternalMemory.WaterLevel1Max_write(1900);
InternalMemory.WaterLevel1Min_write(590);
InternalMemory.WaterLevel2Max_write(1900);
InternalMemory.WaterLevel2Min_write(590);
InternalMemory.WaterLevel3Max_write(1900);
InternalMemory.WaterLevel3Min_write(590);
InternalMemory.WaterLevel4Max_write(1900);
InternalMemory.WaterLevel4Min_write(590);
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+20, MENU_START_ROW*3, "Memory Updated");
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+25, MENU_START_ROW*6, "You can now");
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+25, MENU_START_ROW*7, "upload your");
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+33, MENU_START_ROW*8, "INO code") ;
wdt_reset();
regards
olivier
No, not this code.
You should add it to the code you are going to use on your RA.
Just use the Wizard and when it choose to generate the code and then add that line to the code before you upload it to your RA.
hawaiiensis38
hi Rimai
I'm not a specialist like you can you please send me an screen shot please how to do
my email address: olivier3821@free.fr
hawaiiensis38
i know that is a piss of cat for you
but for me!!!
olivier
but for me!!!
olivier
Did you follow the instructions on the manual to upload a code?
Are you able to upload any of the example codes?
Can you post the code you are trying to upload that is generating the error and what exactly the error is?
I'm not sure I'm understanding what you are getting.
hawaiiensis38
Absolutely, i follow step by step
the RA was working well, showing everything but not the light parameters
now, that i have built my DIY Led light i want to used it with the RA
- Setup the computer with the latest version
- Loading the Initial Memory and the RA shows this error
" No Internal Memory Found"
Olivier
Olivier
Add this right before ReefAngel.Init() to the code you posted above:
Or upload this newer version of the code:
ReefAngel.Init();
wdt_reset();
hawaiiensis38
hello rimai
thanks for the reply
but, like i told you since the beginning how to add this code to the RA
you hav emy email please send me some screen shot how to do
je suis charlie
merci
olivier
je suis charlie
merci
olivier
hawaiiensis38
and can i do hat without connecting the ph and temp sensor?
olivier
olivier
hawaiiensis38
No help???
i will try myself to find how to do
i will never return to this forum
hawaii
hawaii
Have you read the manual? Have you uploaded code before? I'm not sure what difficulty you are having. You don't need anything connected to upload code but power and the serial cable.
hawaiiensis38
Inievo
i make this step several times
here is what i do to upload the RA:
Setup your computer
Windows
1.Download the latest version of the Reef Angel Installer
at http://www.reefangel.com/download.aspx
2.Follow the step by step instructions of the installer.
3.It will take care of installing all the necessary drivers and software.
For more detailed information, please watch the installation videos here:
http://forum.reefangel.com/viewtopic.php?f=15&t=60
2)Loading your Initial Memory Settings The Reef Angel Controller stores several setting in a non
- volatile type of memory, which means you can rest
assured that your settings will remain intact and won’t be lost in the case of power interruption or
reboot of the controller.
A newly acquired Reef Angel will not have any settings stored in the memory and you need to set them up before
you can start using any custom code.
1.Make sure the Reef Angel Controller is powered up.
2. Connect the USB
- TTL converter cable to your PC.
3. Connect the USB
- TTL converter cable to your Reef Angel Controller.
Note: Make sure you connect the cable as the picture below.
The black wire must be the right
- most position and the 2 left
- most pins must be unconnected. Failure to do so can lead to damage to your Reef Angel Controller head unit and/or cable.
4. Open the Arduino Environment software.
5. Depending on which controller you purchased, make sure you have “Reef Angel Controller w/optiboot”
or “Reef Angel Plus Controller” selected under the menu “Tools
- > Board”.
6. Go to menu “File
- >Sketchbook
- >Example Codes” and select “InitialInternalMemory”
7. Click the button “Upload” or go to menu “File” and select “Upload”
8. The controller will start blinking the status LED and will show your initial settings on the screen when it
has completed the upload process.
After this i have the message on the RA "No Internal memory Found"
before my RA was showing all the menu except the light menu
Merci for your help
regards
olivier
Setup your computer
Windows
2. Connect the USB
3. Connect the USB
- > Board”.
6. Go to menu “File
- >Sketchbook
Merci for your help
regards
olivier
hawaiiensis38
hello
i found the error, it was not necessary to connect the the ph & temp probe for this.
with the new version code that rimai give tome it works.
i loading my first code and restore back the preloaded code to the RA.
But, why on the main menu i have:
1. Feeding
2. Water Change
3. Ato Clear
4. overheat clear
5. Ph Calibration
6. Version
7. Exit
i don't have the "Light; Timeouts; Setup" option?
"Temp" because, the probe are not connected?
all the number 1 to 8 are in red
the date: 01/01/00
the time is correct
Thank you for all you support, i will play with and found how to used it properly
regards
Olivier
1. Feeding
2. Water Change
3. Ato Clear
4. overheat clear
5. Ph Calibration
6. Version
7. Exit
the date: 01/01/00
the time is correct
regards
Olivier
hawaiiensis38
I configure the RA with or without the dimming expansion and wifi attachment
but, he cannot generate and upload the code
i have a message "an error was occurred please try again"
i can only generate
but, i can see all the menu that i have created and the light option too
tomorrow i will attach and connect everything that i need on the RA and use it basically
hawaii
i can only generate
hawaii
hawaiiensis38
hello
what i can do for have the right code for use the RA
to incriminate the date
i use the driver Mean Well ELN-60-48P can i start the % level dimming level at 10%instead 15ùat the controller show
hawaii
hawaii
Use the wizard to create the code. It's easier to set the controller and settings with it.
hawaiiensis38
i do that but the message are:"an error was occurred please try again"
i can only "generate" but not "upload and generate"
hawaii
hawaii
So generate and then save the file. Then try again to upload. This way you can see what the upload error is.
hawaiiensis38
Inievo
i try to do what you propose
same thing, i Upload the code
here is what i found
On the RA main menu or setup :LED PMW
Setup LED what means "AP" and "DP"
i have the value 20% on each
hawaii
ReefAngel.LightsOnPorts = Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,245,260 );
ReefAngel.DosingPumpRepeat( Port2,0,60,60 );
ReefAngel.CO2Control( Port3,701,699 );
ReefAngel.StandardATO( Port4,300 );
ReefAngel.StandardLights( Port6,11,0,23,0 );
ReefAngel.PWM.SetDaylight( PWMParabola(11,0,22,0,15,100,15) );
ReefAngel.PWM.SetActinic( PWMParabola(10,0,23,0,15,100,15) );
hawaii
hawaiiensis38
I forget i don't have the possibilities to change the time and date
hawaii
hawaii
Put this in the setup custom code section
ReefAngel.AddDateTimeMenu();
AP = Actinic Port
DP = Daylight Port
AP = Actinic Port
DP = Daylight Port
We need to know what the error that you are getting and not your code.
I have a feeling that you have a standard RA that has very limited memory space and you are going above the memory capacity.
What RA do you have?
hawaiiensis38
i do what you tell me but, not working
i put the code here tell me if it's correct:
on the wizard screen on the little windows down i have this in frenchi cannot copy:
binary size of the sketch: 34 162 octets (max 32256)
processing.app.debug.RunnerException: Sketch to big
http://www.ardino.cc/en/guide/Troubleshooting#size for help
at processing.app.Sketch.size (Sketch.java:1844)
at processing.app.Sketch.build (Sketch.java.1775)
at processing.app.Sketch.exportApplet (Sketch.jav.1797)
at processing.app.Sketch.exportApplet (Sketch.java.1783)
at processing.app.Editor$DefaultExportHandler.run Editor.java:2357)
at java.lang.Thread.run(Thread.java:619)
=> The RA is a standard and old one about 3 years now
hawaii
then upload nothing////// Place your custom code below here
hawaii
There is your problem.
You don't have enough space upload this code.
Your RA has a very limited memory size and you are trying to do too much with it.
I recommend you upgrading to the RA+ and you won't have any problems with memory size.
Your other options to download an older version (1.0.9) of the libraries and try with that.
