Auto Feed routine
Spotted
Auto Feed routine
Ok, so is there any way to get the system to kick into feeding mode and then trigger an automatic feeder? I understand we can hack a couple of different auto feeding systems to work with a wall wart to trigger it, but is there any way to trigger feed mode a couple minutes before triggering the feeder?
Spotted
Re: Auto Feed routine
Or alternately, if I add in this line, and coordinate it with an auto fish feeder will that work too?
Do I need an esle statement for if it is not 6PM?
if ((now()%SECS_PER_DAY==64800)) //if it is 6 pm
ReefAngel.FeedingModeStart(); //START FEEDING MODE
}- lnevo
Nope. That will trigger the feeding mode to start at 6. You'll need to add a second one when you want to trigger the relay for your auto-feeder. That would should have an else to make sure the relay turns off.
Spotted
Well yes that was the basic idea, to get my RA to go into feed mode. Then the auto feed wohld start a minute or 2 later, but manuall on its own, not through my RA. Im on a time crunch and wont have enough time to mod the feeder before I leave. So I figure automate what I could, use the feeder as is and have it feed 2 minutes after feed mode starts in my RA.
Either way
But sounds like you have the jist of it.
Spotted
{ReefAngel.FeedingModeStart(); //START FEEDING MODE}The first line checks to see if the time is 6PM. If it is then executes the commands in the brackets. Right?
If I add a second time of day will this work too?
if ((now()%SECS_PER_DAY==28800)) //if it is 8 AM
if ((now()%SECS_PER_DAY==64800)) //if it is 6 PM
Is that right? This should go into the loop section of the sketch also, right?
Spotted
YAY!! So this should work and it is in the right spot?
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
ReefAngel.LightsOnPortsE[0] = Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port7Bit;
InternalMemory.OverheatTemp_write( 815 );
ReefAngel.Relay.On( Port3 );
ReefAngel.SingleATO( true,Port1,120,10 );
ReefAngel.StandardLights( Port2,19,0,7,0 );
ReefAngel.StandardLights( Port4,10,0,20,0 );
ReefAngel.StandardLights( Port5,6,0,22,0 );
ReefAngel.StandardHeater( Port6,780,805 );
ReefAngel.Relay.DelayedOn( Port7,5 );
ReefAngel.Relay.DelayedOn( Port8,3 );
ReefAngel.DosingPumpRepeat( Box1_Port3,0,60,170 );
ReefAngel.StandardLights( Box1_Port7,13,0,17,0 );
ReefAngel.StandardLights( Box1_Port8,12,0,18,0 );
ReefAngel.PWM.SetDaylight( PWMParabola(13,0,16,0,10,80,10) );
ReefAngel.PWM.SetActinic( PWMSlope(10,0,18,0,15,95,80,15) );
{ReefAngel.FeedingModeStart(); //START FEEDING MODE}[/color]
ReefAngel.Portal( "Spotted" );
