New DCPump Modes - How to code???
Paul_Velasco
Is there a place where the new modes are explained and how to code? Getting ready to upgrade to new LIB 1.1.1 and would like to include the new modes.
Thanks in advance and apologies if this has been answered before. I tried searching.
- cosmith71
Re: New DCPump Modes - How to code???
They're easy if you're using the DCPump libraries already.
Generates a random flow from midpoint-offset to midpoint+offset. For example, if you use:
You'll get a random flow that ranges between 30 and 70.
Generates a long, slow sine wave. Speed is the max speed, duration (in minutes), and threshold is the minimum speed. If you leave off threshold it will use 30 (or whatever you have set with DCPump.Threshold).
I'm not familiar with Sine. Maybe someone else can chime in.
ReefAngel.DCPump.SetMode(Else,midpoint,offset);Code: Select all
ReefAngel.DCPump.SetMode(Else,50,20);Code: Select all
ReefAngel.DCPump.SetMode(Gyre,speed,duration,threshold);I'm not familiar with Sine. Maybe someone else can chime in.
- cosmith71
Paul_Velasco
Thanks man, you are always a great help!!!!
Anyone with the Sine mode help? Or will I be just duplicating with the Gyre Mode.
- cosmith71
You're welcome!
Paul_Velasco
ReefAngel.PWM.SetDaylight( GyreMode(30,100,10,true); //Ramp up to 70% in 10mins in sync mode
ReefAngel.PWM.SetActinic( SineMode(30,100,10,true)); //Ramp up to 70% in 10mins in sync mode GyreMode is not working?
- cosmith71
That code will run it from 30% to 10% over 100 minutes.
Jebao's generally don't work well under 30%. Also, this is a very long cycle time (1 hour 40 minutes). What is it not doing?
Paul_Velasco
The pumps limit is right at 30%, verified operation at that level.
I thought the 10 was the duration, so 10 minutes not 100? Otherwise I will change the code.
It does not recognize GyreMode. The text, GyreMode, stays black in my IDE. Usually if accepted it will turn the text to orange. Load the program and the pump runs at 0% (Looking in my RA Client). I have Lib V 1.1.1 loaded as well. Else mode and Sine mode work perfect.
The color change on the text is probably an oversight on my part.
We can pick and choose which words turn which color.
I'll add GyreMode to the list.
Paul_Velasco
So is duration wrong?
This is how I coded
GyreMode( Low %, High%, Duration min, bolean)
Is it really
GyreMode( Low %, Duration min, High%, bolean)
This is how I coded
Is it really
- cosmith71
I believe it's high, duration minutes, low.
Paul_Velasco
OK will try
I coded it in error at first, gave me compile error Too few arguments , GyreMode (Byte, Byte, Int, Boolean). So I thought the first two arguments were Low% and High%.
Will change to make the duration in the middle.
This is the function arguments:
byte GyreMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync);
- cosmith71
There you go.
Paul_Velasco
ReefAngel.PWM.SetDaylight (GyreMode(40,100,10,true) ); // Short pulse at 60% with 200m
ReefAngel.PWM.SetActinic(GyreMode(40,100,10,false) ); // Short pulse at 60% with 200ms pulse on anti-sync modeIt is definitely not working with this code??? Anything amiss?
- cosmith71
Post the rest of the code.
Paul_Velasco
unsigned long LastUpdate1=0; // For virtual Vinegar dosing pumps
unsigned long LastUpdate2=0; // For virtual Magnesium dosing pumps
unsigned long LastUpdate3=0; // For virtual ATO dosing pump
ReefAngel.FeedingModePortsE[0] = Port1Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit | Port5Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardHeater( Port7,750,755 );
ReefAngel.StandardFan( Port8,760,800 );
ReefAngel.Relay.DelayedOn( Box1_Port1,5 );
ReefAngel.StandardLights( Box1_Port3,20,0,8,0 );
//ReefAngel.WaterLevelATO( Box1_Port7,60,48,50 );
ReefAngel.RF.SetMode( Constant,75,100);
//Use salinity compensation
ReefAngel.Salinity.SetCompensation(0);
//Only use the ATO when no one is in house and there is water in reservior
//Use Channel 4&2 as Redundant Controls.
if (hour()>=6 && hour()<=23)
if (ReefAngel.WaterLevel.GetLevel(4)<=47 && ReefAngel.WaterLevel.GetLevel(1)>0) ReefAngel.Relay.On(Box1_Port7);
if (ReefAngel.WaterLevel.GetLevel(4)>50) ReefAngel.Relay.Off(Box1_Port7);
//Turn-off Skimmer whhen skimmer tank is full
if (ReefAngel.WaterLevel.GetLevel(3)>=90)
ReefAngel.Relay.Off(Box1_Port1);
}else{
//How about some WaveMotion with the Vortech
static time_t feeding;
// Time schedule first
if (hour()>=6 && hour()<7) {
ReefAngel.PWM.SetDaylight( LongPulseMode(30,100,5,true) ); // Long pulse hi/low 50%20% 10s pulse on sync mode
ReefAngel.PWM.SetActinic( LongPulseMode(30,100,5,false) ); // Long pulse hi/low 50%20% 10s pulse on anti-sync mode
} else if (hour()>=7 && hour()<8) {
ReefAngel.PWM.SetDaylight ( ElseMode( 80,20, true) ); // Short pulse at 60% with 200m
ReefAngel.PWM.SetActinic( ElseMode(80,20,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
} else if (hour()>=8 && hour()<10) {
ReefAngel.PWM.SetDaylight( SineMode(30,100,180,true)); //Ramp up to 100% in 3mins in sync mode
ReefAngel.PWM.SetActinic( SineMode(30,100,180,true)); //Ramp up to 100% in 3mins in sync mode
} else if (hour()>=10 && hour()<11) {
ReefAngel.PWM.SetDaylight( ShortPulseMode(30,100,200,true) ); // Short pulse at 60% with 200ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(30,100,200,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
} else if ( (hour()>=11 && hour()<13) && (now()-feeding > SECS_PER_DAY) ) { // We haven't fed today
ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,100,500,true) );
ReefAngel.PWM.SetActinic( NutrientTransportMode(30,100,500,false) );
} else if (hour()>=11 && hour()<13) {
ReefAngel.PWM.SetDaylight( ReefCrestMode(90,10,true) ); // ReefCrest at 70% +/- 20% on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(90,10,false) ); // ReefCrest at 70% +/- 20% on anti-sync mode
} else if (hour()>=13 && hour ()<14) {
ReefAngel.PWM.SetDaylight( ShortPulseMode(30,100,500,true) ); // Short pulse at 60% with 200ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(30,90,500,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
} else if (hour()>=14 && hour()<15) {
//ReefAngel.PWM.SetDaylight ( GyreMode( 30, 100, 10, true) ); // Short pulse at 60% with 200m
//ReefAngel.PWM.SetActinic( GyreMode(30,100, 10, true) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
} else if (hour()>=15 && hour()<16) {
ReefAngel.PWM.SetDaylight( SineMode(30,100,30,true)); //Ramp up to 70% in 10mins in sync mode
ReefAngel.PWM.SetActinic( SineMode(30,100,30,true)); //Ramp up to 70% in 10mins in sync mode
} else if (hour()>=16 && hour()<17) {
ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,100,250,true) );
ReefAngel.PWM.SetActinic( NutrientTransportMode(30,100,250,false) );
//ReefAngel.PWM.SetDaylight( ElseMode(75,20,true) );
//ReefAngel.PWM.SetActinic( ElseMode(75,20,false) );
//ReefAngel.PWM.SetDaylight( ReefCrestMode(75,25,true) ); // ReefCrest at 70% +/- 20% on sync mode
//ReefAngel.PWM.SetActinic( ReefCrestMode(75,25,false) ); // ReefCrest at 70% +/- 20% on anti-sync mode
} else if (hour()>=17 && hour ()<19) {
ReefAngel.PWM.SetDaylight( SineMode(30,100,20, true)); //Ramp up to 70% in 10mins in sync mode
ReefAngel.PWM.SetActinic( SineMode(30,100,20, false)); //Ramp up to 70% in 10mins in sync mode
//ReefAngel.PWM.SetDaylight( ShortPulseMode(10,100,200,true) ); // Short pulse at 60% with 200ms pulse on sync mode
//ReefAngel.PWM.SetActinic( ShortPulseMode(10,100,200,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
} else {
//ReefAngel.PWM.SetDaylight (GyreMode(40,100,10,true) ); // Short pulse at 60% with 200m
//ReefAngel.PWM.SetActinic(GyreMode(40,100,10,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
//ReefAngel.PWM.SetDaylight ( ElseMode(80,20, true) ); // Short pulse at 60% with 200m
//ReefAngel.PWM.SetActinic( ElseMode(80,20,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
// If we are feeding override the schedule
ReefAngel.PWM.SetDaylight(30);
ReefAngel.PWM.SetActinic(30);
//Vortech
ReefAngel.RF.SetMode( Constant,50,100 );
feeding=now();
// If we have finished feeding, start NTM for 3 hours
if (now()-feeding < 3*SECS_PER_HOUR)
//vortech
ReefAngel.RF.SetMode(Smart_NTM,100,10);
//Do not use the memory bits inside the Vortech
//Time based Vortech Schedule
if (hour()>=9 && hour()<10) {
ReefAngel.RF.SetMode(ReefCrest,100,10);
ReefAngel.RF.SetMode(Smart_TSM,100,10);
} else if (hour()>=11 && hour()<12) {
ReefAngel.RF.SetMode(ShortPulse,100,10);
} else if (hour()>=12 && hour()<13) {
} else if (hour()>=13 && hour()<14) {
} else if (hour()>=14 && hour()<15){
ReefAngel.RF.SetMode(LongPulse,100,10);
} else if (hour()>=17 && hour()<18) {
} else if (hour()>=18 && hour()<19) {
} else if (hour()>=19 && hour()<20) {
} else if (hour()>=20 && hour()<21){
} else {
//ReefAngel.RF.SetMode(Lagoon,40,10);
ReefAngel.RF.SetMode(Else, 80,20);
//Code to make Vodka Dosing Work one time a day for 11 mins
//Turn on at 8:00 AM
ReefAngel.DosingPumpRepeat(Box1_Port6,480,1440,450);
///Code to make Vinegar Dosing Work 4 mins
ReefAngel.DosingPumpRepeat(Box1_Port8,0,60,120);
///Do not turn on Vinegar if lights are off
if (hour()<=8 || hour()>21) {
ReefAngel.Relay.Off(Box1_Port8);
//Code to make Magnesium Dosing Work
ReefAngel.DosingPumpRepeat(Box1_Port4,15,60,120);
//Code to check that the dosing pumps are running
// ******************* Turn on imaginary relays for 5 minutes when dosing pumps activate so Portal can track them *******************
// Vinegar port
if (ReefAngel.Relay.Status(Box1_Port8) && LastUpdate1==0)
LastUpdate1 = now();
ReefAngel.Relay.On (Box2_Port1);
if (now() - LastUpdate1 >= 300 && LastUpdate1 != 0)
LastUpdate1 = 0;
ReefAngel.Relay.Off (Box2_Port1);
// Magnesium Port
if (ReefAngel.Relay.Status(Box1_Port4) && LastUpdate2==0)
LastUpdate2 = now();
ReefAngel.Relay.On (Box2_Port2);
if (now() - LastUpdate2 >= 300 && LastUpdate2 != 0)
LastUpdate2 = 0;
ReefAngel.Relay.Off (Box2_Port2);
// ATO Port
if (ReefAngel.Relay.Status(Box1_Port7) && LastUpdate3==0)
LastUpdate3 = now();
ReefAngel.Relay.On (Box2_Port3);
if (now() - LastUpdate3 >= 300 && LastUpdate3 != 0)
LastUpdate3 = 0;
ReefAngel.Relay.Off (Box2_Port3);
// This should always be the last line1
ReefAngel.Portal( "Paul_Velasco" );
- cosmith71
How is it not working? What is it doing/not doing?
Paul_Velasco
(I uncomment in the else statement and comment the other mode so the gyre is only one working)
When I look at the ReefClient on my desktop I get 0% for the pumps on the two channels when running GyreMode.
I physically look at the pumps and they are stopped.
Any of the other modes I run on those channels work perfectly.
Raised the lower limit to 40% thinking that may have been the problem.
Paul_Velasco
- cosmith71
I uncommented the GyreModes and uploaded your code to one of my RA+ units. I manually changed the time to 1400 and 1900 and it worked both times.
The only thing I can recommend is doing an un-install/re-install of the the RA software on your computer. Maybe you have a corrupted library.
- cosmith71
The only potential problem I see is that between 1400 and 1500 you have both pumps set to sync. That means they will both be on for 10 minutes and off for 10 minutes at the same time.
Paul_Velasco
Paul_Velasco
Reinstall did not work?
Is there something in the registry to delete?
Upload this code and see what you get:
It worked for me.
Paul_Velasco
To Close this out:
Uninstalled and resinstalled Arduino application, did this twice. Then reinstalled once again last night and it worked?? No idea why it just worked.
davaraj
Are these DCPump codes meant for a single pump? How do I code for 2 pumps connected to the Actinic and DayLight channels?cosmith71 wrote:They're easy if you're using the DCPump libraries already.
Generates a random flow from midpoint-offset to midpoint+offset. For example, if you use:Code: Select all
You'll get a random flow that ranges between 30 and 70.Code: Select all
Generates a long, slow sine wave. Speed is the max speed, duration (in minutes), and threshold is the minimum speed. If you leave off threshold it will use 30 (or whatever you have set with DCPump.Threshold).Code: Select all
Dr Davaraj
You will have lines like this in the setup section of your code
ReefAngel.DCPump.DaylightChannel = AntiSync;
If you want to disable one channel you can set it to None.
If you want both pumps to do the same thing then set them both to Sync.
davaraj
I have recoded like this. I do havelnevo wrote:You will have lines like this in the setup section of your code
In the setup section.
///////Place your custom code below here
if (hour()>=4 && hour()<8)
ReefAngel.DCPump.SetMode(Sine, 30, 40);
else if (hour()>=8 && hour()<12)
ReefAngel.DCPump.SetMode(TidalSwell, 55); // TidalSwell at 55%
else if (hour()>=12 && hour()<16)
ReefAngel.DCPump.SetMode(millis();1200>750?50:0);
else if (hour()>=16 && hour()<19)
ReefAngel.DCPump.SetMode(LongPulse, 0, 50, 10); // Long pulse at 0% to 50% with 10s pulse
else if (hour()>=19 && hour()<23)
ReefAngel.DCPump.SetMode(Else, 40, 10); // ElseMode 40 +/- 10%
ReefAngel.DCPump.SetMode(Gyre, 30, 50, 10); //GyreMode from 30% to 50% for 10 minutes
When I run 'verify' code it compiles, except for:
ReefAngel.DCPump.SetMode(TidalSwell, 55); and
When I insert this:
ReefAngel.DCPump.SetMode(TidalSwell, 55, true); it compiles for this mode. However 'millis' gives errors. How do I code for millis (standing wave like W1 in Jebao controller)?
You need 3 arguments to SetMode separated by a comma. Mode Speed and Duration. The first only has 2 and no comma and the second, that code block represents one argument and it represents a speed.ReefAngel.DCPump.SetMode(TidalSwell 55); and
Try this:
ReefAngel.DCPump.SetMode(TidalSwell,55,0);
ReefAngel.DCPump.SetMode(Constant,millis();1200>750?50:0,0);
