I don't have the WiFi attachment currently.
Will I be able to reset ATO alarm remotely without the WiFi attachment? I have read somewhere on this forum that there is a direct browser commend http://yourreefangelip:2000/mt that will do the trick, but does this work without the Wifi attachment?
I also have a laptop which connects to Reef Angel head unit via the USB port, which I can access remotely. Is there a way to reset ATO alarm? using the Client Suite 3.0 memory utility or something similar?
Bboss
ATO remote reset
Re: ATO remote reset
Open Serial Monitor on Arduino under menu Tools.
Make sure that it is set to "57600 baud" and "Both NL & CR".
Type the following command:
Is this on a RA or RA+?
You need to have the wifi attachment feature enabled. If it is RA+, it is enabled by default. If it is RA, you must add this to setup();
GET /mt HTTP
ReefAngel.AddWifi();
bboss
Thank you so much, Roberto.
I will try it out tonight.
bboss
Works perfectly. Thanks again.
Will I be able to issue most or all wifi commands in this similar fashion using the Serial Console?
