Made the change, no difference. stays at 100% until feeding mode exitslnevo wrote:Sorry for the late reply. Please try this code.
#include <SoftwareSerial.h> #include <ReefAngel_Features.h> #include <Globals.h> #include <RA_Wifi.h> #include <Wire.h> #include <OneWire.h> #include <Time.h> #include <DS1307RTC.h> #include <InternalEEPROM.h> #include <RA_NokiaLCD.h> #include <RA_ATO.h> #include <RA_Joystick.h> #include <LED.h> #include <RA_TempSensor.h> #include <Relay.h> #include <RA_PWM.h> #include <Timer.h> #include <Memory.h> #include <RA_Colors.h> #include <RA_CustomColors.h> #include <Salinity.h> #include <RF.h> #include <IO.h> #include <ORP.h> #include <AI.h> #include <PH.h> #include <WaterLevel.h> #include <Humidity.h> #include <DCPump.h> #include <PAR.h> #include <ReefAngel.h> /* #define Heater 1 #define Return 2 #define 3 #define Skimmer 4 #define Vortech1 5 #define Vortech2 6 #define ATO 7 #define Sump Light 8 */ ////// Place global variable code below here byte vtechmode, vtSpeed, vtDuration; ////// Place global variable code above here void setup() { // This must be the first line ReefAngel.Init(); //Initialize controller // Ports toggled in Feeding Mode ReefAngel.FeedingModePorts = Port2Bit; // ReefAngel.FeedingModePortsE[0] = 0; // Ports toggled in Water Change Mode // ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit; // ReefAngel.WaterChangePortsE[0] = 0; // Ports toggled when Lights On / Off menu entry selected // ReefAngel.LightsOnPorts = 0; // ReefAngel.LightsOnPortsE[0] = 0; // Ports turned off when Overheat temperature exceeded ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit; // ReefAngel.OverheatShutoffPortsE[0] = 0; // Use T1 probe as temperature and overheat functions ReefAngel.TempProbe = T1_PROBE; ReefAngel.OverheatProbe = T1_PROBE; // Set the Overheat temperature setting InternalMemory.OverheatTemp_write( 830 ); ReefAngel.AddRANet(); // Ports that are always on ReefAngel.Relay.On( Port2 ); ReefAngel.Relay.On( Port3 ); ReefAngel.Relay.On( Port4 ); ReefAngel.Relay.On( Port5 ); ReefAngel.Relay.On( Port6 ); ReefAngel.Relay.On( Box1_Port1 ); ReefAngel.Relay.On( Box1_Port2 ); ReefAngel.Relay.On( Box1_Port3 ); ReefAngel.Relay.On( Box1_Port4 ); ReefAngel.Relay.On( Box1_Port5 ); ReefAngel.Relay.On( Box1_Port6 ); ReefAngel.Relay.On( Box1_Port7 ); ReefAngel.Relay.On( Box1_Port8 ); ////// Place additional initialization code below here // Hardcode calibrations // ReefAngel.PHMin=576; // PH7.0 // ReefAngel.PHMax=842; // PH10.0 // ReefAngel.SalMax=3300; // 35ppt ////// Place additional initialization code above here } void loop() { vtechmode=InternalMemory.RFMode_read(); vtSpeed=InternalMemory.RFSpeed_read(); vtDuration=InternalMemory.RFDuration_read(); static unsigned long feeding; ReefAngel.StandardHeater( Port1,778,782 ); ReefAngel.WaterLevelATO( Port7,180,71,74 ); ReefAngel.StandardLights( Port8,15,0,2,0 ); ReefAngel.PWM.SetChannel( 0,PWMSlope(19,00,21,00,15,51,20,0) ); //MOON ReefAngel.PWM.SetChannel( 1,PWMSlope(12,30,20,00,15,50,30,0) ); //RB ReefAngel.PWM.SetChannel( 2,PWMSlope(12,20,20,00,15,95,30,0) ); //WHITE ReefAngel.PWM.SetChannel( 3,PWMSlope(12,15,20,00,15,70,30,0) ); //BLUE&CYAN ReefAngel.PWM.SetChannel( 4,PWMSlope(12,00,20,30,15,70,30,0) ); //UV if ( ReefAngel.HighATO.IsActive()) { ReefAngel.Relay.On(Port2); } else { ReefAngel.Relay.Off(Port2); } ReefAngel.RF.UseMemory=true; /* if (hour() >=13 && hour() < 20) { // if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0); ReefAngel.RF.UseMemory=true; // ReefAngel.RF.SetMode(ReefCrest,60,20); if (ReefAngel.DisplayedMenu==FEEDING_MODE) { feeding=now(); } if (now()-feeding<5400) { // if (now()-feeding > 1 && now()-feeding < 5400) { // 1 second after feeding mode until 90 minutes after feeding mode. ReefAngel.RF.UseMemory=false; ReefAngel.RF.SetMode(Smart_NTM,75,10); } } else { ReefAngel.RF.UseMemory=false; ReefAngel.RF.SetMode(Constant,10,0); } if (vtechmode!=InternalMemory.RFMode_read()) InternalMemory.RFMode_write(vtechmode); if (vtSpeed!=InternalMemory.RFSpeed_read()) InternalMemory.RFSpeed_write(vtSpeed); if (vtDuration!=InternalMemory.RFDuration_read()) InternalMemory.RFDuration_write(vtDuration); */ // This should always be the last line ReefAngel.Portal( "bencollinz" ); ReefAngel.ShowInterface(); } void DrawCustomMain() { char text[7]; // Date and Time ReefAngel.LCD.DrawDate( 6, 2 ); ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 132, 11); pingSerial(); ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech"); ReefAngel.LCD.Clear(255, 1, 19, 128, 29); if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant"); else if (vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon"); else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest"); else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse"); else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse"); else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp."); else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell"); else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night"); ReefAngel.LCD.DrawText(0,255,4,30,"RF Speed:"); ReefAngel.LCD.Clear(255,59,29,128,39); ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,71,31,vtSpeed); ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,90,31,"/"); ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,100,31,vtDuration); ReefAngel.LCD.DrawText(0,255,10,40,"Salt"); ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10); ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 50, text, Num8x8); pingSerial(); /* ReefAngel.LCD.DrawText(0,255,50,40,"Fresh"); ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10); ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 50, 50, text, Num8x8); pingSerial(); */ ReefAngel.LCD.DrawText(0,255,100,40,"pH"); ConvertNumToString(text, ReefAngel.Params.PH, 100); ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 50, text, Num8x8); pingSerial(); ReefAngel.LCD.DrawText(0,255,13,58,"Salinity"); ConvertNumToString(text, ReefAngel.Params.Salinity, 10); ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 13, 68, text, Num8x8); pingSerial(); // water level ReefAngel.LCD.DrawText(0,255,68,58,"WL"); ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 68, 68, ReefAngel.WaterLevel.GetLevel() ); pingSerial(); // Main Relay Box byte TempRelay = ReefAngel.Relay.RelayData; TempRelay &= ReefAngel.Relay.RelayMaskOff; TempRelay |= ReefAngel.Relay.RelayMaskOn; ReefAngel.LCD.DrawOutletBox( 12, 108, TempRelay ); pingSerial(); // Relay Expansion TempRelay = ReefAngel.Relay.RelayDataE[0]; TempRelay &= ReefAngel.Relay.RelayMaskOffE[0]; TempRelay |= ReefAngel.Relay.RelayMaskOnE[0]; ReefAngel.LCD.DrawOutletBox( 12, 120, TempRelay ); pingSerial(); } void DrawCustomGraph() { } /* void Heater2(byte HeaterRelay, int LowTemp, int HighTemp) { if (ReefAngel.Params.Temp[T2_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0 if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater } void Heater1(byte HeaterRelay, int LowTemp, int HighTemp) { if (ReefAngel.Params.Temp[T1_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0 if (ReefAngel.Params.Temp[T1_PROBE] <= LowTemp && ReefAngel.Params.Temp[T1_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater if (ReefAngel.Params.Temp[T1_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater } */
My code - now with RAnet
bencollinz
Re: My code - now with RAnet
bencollinz
and I can't even remove the RAnet code without getting this error
"C:\Users\user\Documents\Arduino\libraries\Globals/Globals.h:348: error: 'SoftwareSerial' does not name a type"
Maybe need to reinstall the libraries fresh, something doesnt seem right
If you remove RANet, you must also remove the include on top "#include <SoftwareSerial.h>"
bencollinz
rimai wrote:If you remove RANet, you must also remove the include on top "#include <SoftwareSerial.h>"
How do I use
ReefAngel.StandardHeater( Port1,778,782 );-
bencollinz
figured it out. yes, the same way.bencollinz wrote:rimai wrote:If you remove RANet, you must also remove the include on top "#include <SoftwareSerial.h>"
How do I usebut Box1_Port1? The same way?Code: Select all
