#include <Timer.h>U
#include <SoftwareSerial.h>
ReefAngel.Use2014Screen();
ReefAngel.AddRANet();
// Ports toggled when relay looses communication
ReefAngel.Relay.RANetFallBackE[0] = Port1Bit | Port5Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port5Bit;
// Feeding Mode speeds
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardLights( Port1, 13, 0, 23, 00);
ReefAngel.StandardLights( Port3, 13, 0, 23, 05);
ReefAngel.StandardLights( Port7, 23, 0, 7, 05);
ReefAngel.StandardLights( Port8, 23, 0, 7, 05);
ReefAngel.StandardLights( Box1_Port1, 7, 0, 1, 00);
ReefAngel.StandardLights( Box1_Port2, 22, 0, 7, 00);
ReefAngel.StandardLights( Box1_Port7, 19, 0, 23, 00);
if (hour()>=7 && hour()<23) // Turn Moonlights on/off
ReefAngel.PWM.SetChannel( 0, (0));
ReefAngel.PWM.SetChannel( 0, MoonPhase()/4);
if (hour()>=4 && hour()<8)
ReefAngel.PWM.SetDaylight(SineMode(32,40,30,true) ); //SineMode from 30% to 40% for 30 seconds on sync mode
ReefAngel.PWM.SetActinic(SineMode(32,40,30,false) ); //SineMode from 30% to 40% for 30 seconds on anti-sync mode
else if (hour()>=8 && hour()<12)
ReefAngel.PWM.SetDaylight( TidalSwellMode(55,true) ); // TidalSwell at 40% on sync mode
ReefAngel.PWM.SetActinic( TidalSwellMode(55,false) ); // TidalSwell at 40% on sync mode
else if (hour()>=12 && hour()<16)
ReefAngel.PWM.SetDaylight(millis()%1200>750?50:0);
ReefAngel.PWM.SetActinic(millis()%1200<750?0:50);
else if (hour()>=16 && hour()<19)
ReefAngel.PWM.SetDaylight( LongPulseMode(0,50,10,true) ); // Long pulse at 0% to 50% with 10s pulse on sync mode
ReefAngel.PWM.SetActinic( LongPulseMode(0,50,10,false) ); // Long pulse at 0% to 50% with 10s pulse on on anti-sync mode
else if (hour()>=19 && hour()<23)
ReefAngel.PWM.SetDaylight( ElseMode(42,10,true )); // ElseMode on sync mode, 40 +/- 10%
ReefAngel.PWM.SetActinic( ElseMode(42,10,false )); // ElseMode on anti-sync mode, 40 +/- 10%
ReefAngel.PWM.SetDaylight(GyreMode(32,50,10,true) ); //GyreMode from 30% to 50% for 10 minutes on sync mode
ReefAngel.PWM.SetActinic(GyreMode(32,50,10,false) ); //GyreMode from 30% to 50% for 10 minutess on anti-sync mode
ReefAngel.Portal( "davaraj" );
My code with RANet
My code with RANet
Re: My code with RANet
Used this code for feeding mode with ReefAngel battery backup for wavemakers.
This part of code does not work well. One wavemaker runs at full speed:
ReefAngel.DCPump.Mode =millis();
ReefAngel.DCPump.Speed = 1200, 750?50:0;
By the way is this how one codes for DCPump class?
ReefAngel.DCPump.Mode = Sine;
ReefAngel.DCPump.Speed = 30, 40;
ReefAngel.DCPump.Mode = TidalSwell; // TidalSwell at 55% on sync mode
ReefAngel.DCPump.Speed = 55;
ReefAngel.DCPump.Mode=LongPulse; // Long pulse at 0% to 50% with 10s pulse on sync mode
ReefAngel.DCPump.Speed =0,50,10;
ReefAngel.DCPump.Mode=Else; // ElseMode on sync mode, 40 +/- 10%
ReefAngel.DCPump.Speed =40, 10;
ReefAngel.DCPump.Mode=Gyre; //GyreMode from 30% to 50% for 10 minutes on sync mode
ReefAngel.DCPump.Speed = 32, 50, 10;
Close. For Mode, you need to pick a valid mode or. Using millis() is not going to work. This would also cause the mode to change every iteration of loop() which would never keep the mode constant for more than a few milliseconds.davaraj wrote:Used this code for feeding mode with ReefAngel battery backup for wavemakers.
ReefAngel.DCPump.Mode=5;
ReefAngel.DCPump.Speed=60;
Second for Speed, the number needs to be between 0-100. I'm not even sure how the above would compile. 750?50:0 is valid, but not the 1200, part. And that code would always return 50 fro the speed.
This was my original code that worked well.lnevo wrote:Close. For Mode, you need to pick a valid mode or. Using millis() is not going to work. This would also cause the mode to change every iteration of loop() which would never keep the mode constant for more than a few milliseconds.davaraj wrote:Used this code for feeding mode with ReefAngel battery backup for wavemakers.
I changed it to this:
Will the 2nd set of codes work? i know that 'millis' will not work as you have mentioned above.
No it won't work. When you use the DCPump class the Modes have built in parameters for duration and ranges. You can't pass multiple values to Speed.
You can only set one number.
Re: My code with RANet-update
ReefAngel.StandardFan( Box1_Port6, 262,273);
ReefAngel.DCPump.SetMode(Sine,50,30,30) ;
ReefAngel.DCPump.SetMode(TidalSwell,55,0); // TidalSwell at 55% on sync/antisync mode
ReefAngel.DCPump.SetMode(Constant, millis()%1200>750?50:0,0);
ReefAngel.DCPump.SetMode(LongPulse,50,10,0); // Long pulse at 0% to 50% with 10s pulse on sync/antisync mode
ReefAngel.DCPump.SetMode(Else,40,20); // ElseMode sync/antisync, 40 +/- 20%
ReefAngel.DCPump.SetMode(Gyre,50,05,30); //GyreMode from 30% to 50% for 10 minutes on sync/antisync mode
