1. How can I find out wattage rating for the relay box relays? For example, can I plug in a 300 watt heater etc.
2. I want to use a 12v solenoid to control my RO output. Does the RA have a port that can control this solenoid, or would I either need to use a 12v wall wart or buy the 12v power control box?
Ted
Relay box rating and 12v solenoid
Re: Relay box rating and 12v solenoid
1. Yes. You can use up to 5A each port. 10A total for the box though.
2. Best is to use a wall wart. The power control box most likely will not be able to handle.
paperdesk
Thanks! I'm in way over my head with this Reef Angel, but having a blast and learning a lot!
