Reefology's code
Re: Reefology's code
What do you want to do with them...if you want to speed one up or slow one down? Which is currently sync/antisync?
Reefology
Post by Reefology »
Yup, that's what I want. So do I remove the offset then? Leave it at 100? Or change it to some other figure?
I gave you two choices...you answered yup. If you want to speed up the antisync channel then make it 125 for a 25% increase. Or make it 75 for a 25% decrease on the one set to antisync
Reefology
Post by Reefology »
thanks for the info Lee :)
i answered "yup" because i'd like to know how to manipulate the fields/data going forward, don't just want to rely on you guys to write code for me (though at times i need you to and certainly do appreciate it). sorry for the confusion :P
No worries just confusing. All good now
Reefology
Post by Reefology »
Hi all,
How do I figure out why I can't upload a sketch when it complies just fine?
This is the error message I'm getting:
Same message I get when try to upload without cable. Can it be a cable issue? It seemed to work yesterday to upload wifitestcode? Sort of...
Make sure you are connecting the cable correctly on RA. It should be all the way to the right and you should have 2 pins unconnected on the left.
Reefology
Post by Reefology »
Hi Roberto,
Yes thanks, I've uploaded sketches many times so it's definitely not that. Any other ideas?
Reefology
Post by Reefology »
 // DC pumps
    // To run this code must choose Custom in portal
    static int rmode;
    byte modes[] = { NutrientTransport, Sine, ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
    if (now()%1200==0 || changeMode==true) { // Change every 20 (1200seconds) mins or controller reboot
    rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
    changeMode=false;
    static unsigned long feeding;
    if (now()-feeding<3000) {
    // Continue NutrientTranspot Mode for 45 minutes
    ReefAngel.DCPump.Mode=NutrientTransport;
    } else if (now()%SECS_PER_DAY<37800 || now()%SECS_PER_DAY>=81000) { // 10:30am / 10:30pm
    // Night mode (go to 30%)
    ReefAngel.DCPump.Mode=Gyre;
    ReefAngel.DCPump.Speed=30;
    } else if (InternalMemory.DCPumpMode_read()==11) {
    ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
    } else {
hi, based on the code above, I don't understand why my pwm channels have been at 0 for the past 45 mins? can someone help me figure out what I've done wrong? thanks
Reefology
Post by Reefology »
 // DC pumps
    static int rmode;
    changeMode=false;
    } else {
Reefology
Post by Reefology »
 // DC pumps
    static int rmode;
    changeMode=false;
    } else {
What mode do you see in the screen?
Reefology
Post by Reefology »
not sure which screen you're referring to but in the portal, the internal memory keeps getting reset to 0's for both speed and duration? currently the mode alternates but it was set up in custom??
The RA screen. Move the joystick to the right or left.
Or are you using a custom screen?
Reefology
Post by Reefology »
it says normal mode. what is that? don't see it listed in the portal as a mode.
Normal?
Are you sure you are in the RF screen?
Can you send a picture?
Reefology
Post by Reefology »
sorry Roberto, the mode is gyre, duration is 15 and speed is 30
Which channels did you assign for DCPump?
Reefology
Post by Reefology »
lol, I just logged in to tell you i figured it out...had the actinic channel set to None and of course thought I had the pump wired to daylights :p
thanks Roberto
Reefology
Post by Reefology »
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.DayLights( Port2 );
    ReefAngel.StandardLights( Port5, 19,0,7,0);
    ReefAngel.DosingPumpRepeat1( Port6 );
    ReefAngel.DosingPumpRepeat2( Port7 );
    ReefAngel.DosingPumpRepeat3( Port8 );
    ReefAngel.DCPump.LowATOChannel = Sync; // WP40
    ReefAngel.DCPump.HighATOChannel = AntiSync; // SW 8
    ReefAngel.DCPump.AntiSyncOffset=125;
    // DC pumps
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
    if (now()%3600==0 || changeMode==true) { // Change every 60 mins (3600seconds) or controller reboot
    changeMode=false;
    // Continue NutrientTranspot Mode for 30 minutes after feeding
    if (now()-feeding<1800) {
    ReefAngel.DCPump.Speed=80;
    } else if (now()%SECS_PER_DAY>25200 && now()%SECS_PER_DAY<=68400) { // 7am to 7pm
    } else {
Can someone here please tell me why my Jebao wavemaker pump is running full throttle constantly on the ATO high? the ATO low is working great. in fact I made an adaptor to run both pumps on my ATO low and they're working but I'd really like to get the antisync working. The code I'm using in the meantime is below.
thanks
    ReefAngel.StandardLights( Port5 );
    ReefAngel.DCPump.LowATOChannel = Sync; // WP40 & SW 8
    ReefAngel.DCPump.HighATOChannel = None; //
    // DC pumps....................................
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, Else, Gyre, NutrientTransport };
    if (now()%1800==0 || changeMode==true)  // Change every 30 mins (1800seconds) or controller reboot
    changeMode=false;
    ReefAngel.DCPump.Mode=ReefCrest;
    // Night/Quiet mode
      else if (hour()>=2 && hour()<8 ) // 2am to 8am
    ReefAngel.DCPump.SetMode( Sine,35,10 );
      else if (hour()>=15 && hour()<19) // 3pm and 7pm
    ReefAngel.DCPump.SetMode( LongPulse,30,1 );
    //Storm mode
    else if (hour()>=1 && hour()<2) // 1am and 2am
    ReefAngel.DCPump.SetMode( Else,80,15 );
      else if (hour()>=11 && hour()<12) // 11am and 12pm
    ReefAngel.DCPump.SetMode( LongPulse,95,2 );
    else if (hour()>=21 && hour()<22) // 9pm and 10pm
    ReefAngel.DCPump.SetMode( ReefCrest,85,15 );
    } else {
Reefology
Post by Reefology »
    InternalMemory.LCDID_write(255); //this line was added when i got a replacement RA+ board
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.DelayedOn(Port5 );
    ReefAngel.DosingPumpRepeat1( Port7 );
    ReefAngel.DosingPumpRepeat2( Port8 );
    ReefAngel.DCPump.HighATOChannel = AntiSync; // SW-8
    ReefAngel.DCPump.AntiSyncOffset = 125;
    // Wavemaker
    if ( ((hour() >= 2) && (hour() < 8)) || ((hour() >= 15) && (hour() < 19)) ) // off from 2am-8am & 3pm-7pm
        ReefAngel.Relay.Off(Port6);
        ReefAngel.WavemakerRandom( Port6, 30, 300 ); // random between 30 and 300 seconds
    static int rmode;
    changeMode=false;
    ReefAngel.DCPump.Speed=75;
    // Night/Quiet mode
    ReefAngel.DCPump.SetMode( Gyre,40,10 );
    ReefAngel.DCPump.SetMode( ShortPulse,40,30 );
    //Storm mode
    ReefAngel.DCPump.SetMode( Else,70,15 );
    ReefAngel.DCPump.SetMode( ReefCrest,80,15 );
    ReefAngel.DCPump.SetMode( ShortPulse,85,30 );
    } else {
Reefology
Post by Reefology »
Hoping someone can help with this. I'd like to add Seasonal changes to my code but can't get it to compile.
void SeasonalTemps ()
  static int heatArray[][2] = { {782,786},// default in case of error in month=0 (June)
                    {760,764},//January (winter)
                    {764,768},//February (winter)
                    {765,769},//March (early spring)
                    {769,773},//April (spring)
                    {775,779},//May (spring)
                    {782,786},//June (early summer)
                    {789,793},//July (summer)
                    {796,800},//August (summer)
                    {786,790},//September (early fall)
                    {777,781},//October (fall)
                    {770,774},//November (fall)
                    {765,769} };//December (early winter)
  ReefAngel.StandardHeater( Port3,heatArray[month()][0],heatArray[month()][1]);
 }//end seasonalTemps
where exactly do I input this?
you have to simply copy the entire function and paste it into your INO file, most likely at the end of it. well after the last curly brace of the loop.
Reefology
Post by Reefology »
  static int heatArray[][2] = { {780,784},// default in case of error in month=0 (May)
                    {764,768},//January (winter)
                    {768,772},//February (winter)
                    {772,776},//March (early spring)
                    {776,780},//April (spring)
                    {780,784},//May (spring)
                    {784,788},//June (early summer)
                    {788,792},//July (summer)
                    {784,788},//August (summer)
                    {780,784},//September (early fall)
                    {776,780},//October (fall)
                    {772,776},//November (fall)
                    {768,772} };//December (early winter)
  ReefAngel.StandardHeater( Port1,heatArray[month()][0],heatArray[month()][1]);
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit;
    SeasonalTemps ();
    ReefAngel.ActinicLights( Port2 ); //ATS pump
    ReefAngel.DayLights( Port3 ); //ATS light
    ReefAngel.StandardLights( Port4, 23,0,7,0); //Skimmer 11pm-7am
    ReefAngel.DCPump.LowATOChannel = Sync; // SW 8
    //ReefAngel.DCPump.AntiSyncOffset = 125; // % (0-255) of main pump (Sync)
    // koralia 1150
    // if (hour()>=23 || hour()<11) ReefAngel.Relay.Off( Port5 );
    // else ReefAngel.WavemakerRandom( Port5, 120, 1800 );
    // DC pumps
    static int rmode;
    changeMode=false;
    ReefAngel.DCPump.Mode=Else;
    } else if (now()%SECS_PER_DAY<39600 || now()%SECS_PER_DAY>=82800) { // 11pm to 11am
    ReefAngel.DCPump.Speed=40;
    } else {
Reefology
Post by Reefology »
Hoping someone from this great community can help as I'm not sure how to implement this. I'm looking to turn my kalk stirrer (port 7) off between 5pm and 11pm.
if ( hour(now()) >= 17 && hour(now()) <= 23 ) ReefAngel.Relay.Off( Port7 );
if the statement above is correct, where should I input it into my code?
It has to be the line right after the kalkwasser function
Reefology
Post by Reefology »
Hi Roberto,
so like this?
if ( hour(now()) >= 17 && hour(now()) <= 23 ) ReefAngel.Relay.Off(Port7 );
Yes. Looks good
Reefology
Post by Reefology »
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit;
    ReefAngel.Relay.On( Port2 );
    SeasonalTemps();
    ReefAngel.ActinicLights( Port3 ); //Skimmer
    ReefAngel.DayLights( Port4 ); //ATS light
    if ( hour(now()) >= 17 && hour(now()) <= 23 ) ReefAngel.Relay.Off( Port7 ); //kalk dosing off 5pm-11pm
    // koralia 1150
    // DC pumps
    static int rmode;
    changeMode=false;
    } else {
Reefology
Post by Reefology »
hey Roberto, didnt work! any other ideas?
