It is showing in my portal.
Is there a firmware update? I bought this late 2012.
My code:
ReefAngel.FeedingModePortsE[0] = Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit | Port4Bit | Port5Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port5Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.MoonLights( Port2 );
ReefAngel.WaterLevelATO( Port4 );
ReefAngel.DosingPumpRepeat1( Port6 );
ReefAngel.DosingPumpRepeat2( Port7 );
ReefAngel.Relay.DelayedOn( Box1_Port5 );
ReefAngel.Relay.Set( Box1_Port6, !ReefAngel.Relay.Status( Port8 ) );
ReefAngel.RF.ChannelWhiteSlope();
ReefAngel.RF.ChannelRoyalBlueSlope();
ReefAngel.RF.ChannelRedSlope();
ReefAngel.RF.ChannelGreenSlope();
ReefAngel.RF.ChannelBlueSlope();
ReefAngel.RF.ChannelIntensitySlope();
/* Auto feeding mode starts.
Feeder set for 12:00, start feeding mode at 11:55. */
if ( hour() == 11 && minute() == 55 && second() ==0 ) //if time is 11:55:00
ReefAngel.FeedingModeStart(); //start feeding mode
/* Vortech nutrient transport mode (after feeding mode)
// Turn off nutrient transport mode
if (ReefAngel.Relay.Status( Port2 )== 0 && ReefAngel.RF.Mode==Night)
ReefAngel.RF.SetMode(Night_Stop,0,0);
// Turn on Night Mode if Fuge light is on (Fuge comes on at night)
if (ReefAngel.Relay.Status( Port2 )== 1 && ReefAngel.RF.Mode!=Night)
ReefAngel.RF.SetMode(NutrientTransport,75,40);
/* Vortech night mode
Info: you can do ReefAngel.Relay.Status(Port2); which will return 0 (off) or 1 (on) */
// Turn off Night Mode
ReefAngel.RF.SetMode(Night,20,0);
ReefAngel.Portal( "alexwbush" );
