Custom Coding float swithes
Ask in here.
ewaldsreef
Post by ewaldsreef »
Thank you in advance for your valuable time.
I would like one of my float switches in the sump to send an alert, set off the buzzer and activate a relay to engerize a soleniod to cut off the rro water to my top off. once the level drops I would like it to return to normal without needing to clear anything.
I would like the second float to shut off my return( it would monitor water level in the over flow) send an alert and set off the buzzer.
I am still learning the coding. Had my RA over a year now and finally getting around to learning how to do the custom stuff lol.
Again thank you for any help
ewaldsreef
Re: Custom Coding float swithes
also since I am not using the ato function could I remove this from the menu on the ra unit?
Which channel do you have the buzzer connected to?
And which relay port do you want to activate?
ewaldsreef
The buzzer is on the second dimming port. return pump is on port 1and I am looking to
activate port 8 for the shut off valve.
2nd as in channel 1 of dimming expansion?
ewaldsreef
The second port on the main relay box
Ah, we call them actiinic and daylight. Which one is it?
ewaldsreef
Actinic. Thank you
Try this:
boolean alert=false;
  ReefAngel.Init();
  // Low Float for RO water
    ReefAngel.Relay.On(Port8);
    alert=false;
    ReefAngel.Relay.Off(Port8);
    alert=true;
  // High Float for Overflow
    ReefAngel.Relay.On(Port1);
    alert=false;
    ReefAngel.Relay.Off(Port1);
    alert=true;
  if (alert)
    ReefAngel.PWM.SetActinic(100);
    ReefAngel.PWM.SetActinic(0);
ewaldsreef
Thank you so much for your time. I screwed something up lol
I was unsucessful with the code so I tryed to return to my previous code but now the lights dont workwith the timmer. Here is my current code as I have it.
byte buzzer=0;
byte overheatflag=0;
    ReefAngel.FeedingModePorts = Port1Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port6Bit;
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.DayLights( Port2 );
    ReefAngel.Relay.DelayedOn( Port4 );
    ReefAngel.StandardHeater( Port6 );
    buzzer = overheatflag;
    if ( buzzer >= 1 ) buzzer = 100;
    ReefAngel.PWM.SetActinic( buzzer );
    ReefAngel.Portal( "ewaldsreef" );
ewaldsreef
I had AI Vegas on the tank so I did not use the light ports previously. The AIs are not working right now so I went back to my old setup. I have the lights setup to run daylight at 12pm to 9pm with actinics to turn on 30 minute before and after.
Seriusly considering purchasing another setup to learn on and then add to my propigation system in the future. Also purchased and Uno to learn some basics. :D
Again I thank you for your help
ewaldsreef
Got everthing working perfect except the buzzer will not go on when low float is trigger in the sump. It does trigger port 8 Properly
byte buzzer=0;
    ReefAngel.StandardLights(Port2,11,30,21,30);
    ReefAngel.StandardLights(Port3,12,0,21,0);
    alert=false;
    alert=true;
    alert=false;
    alert=true;
  if (alert)
Oh yeah....
One condition was overriding the other. Sorry.
Try this:
byte buzzer=0;
  alert=false;
  if ( buzzer >= 1 ) alert=true;
    alert=true;
    alert=true;
  if (alert)
ewaldsreef
Perfect! Thank you
