Connection Status: Unreachable Address
Related to the Portal
PostPosted: Sun Feb 22, 2015 4:31 pm
I do not believe so...so I need to and how would I tell if I do?
PostPosted: Sun Feb 22, 2015 5:22 pm
Check the portal settings in the portal if it s on turn it off to test first. If that's the issue you need to change the line to ReefAngel.Portal("username", "key");
PostPosted: Sun Feb 22, 2015 5:26 pm
That is so strange.
Everything is correct, but I can't seem to understand what is going on here :(
Your portal should be populating.
PostPosted: Sun Feb 22, 2015 5:44 pm
Something weird I found out.
I still don't know why, but try this.
Change the DDNS keyword to something else and let me know if that works.
PostPosted: Sun Feb 22, 2015 5:45 pm
lnevo wrote:Check the portal settings in the portal if it s on turn it off to test first. If that's the issue you need to change the line to ReefAngel.Portal("username", "key");
Nope it is not on! Good thought though that would have been great if that was it. I just want this thing working so I can mount it on the tank
PostPosted: Sun Feb 22, 2015 5:50 pm
rimai wrote:Something weird I found out.
changed it to reeftank lets see if this is it! controller a reserved word?
PostPosted: Sun Feb 22, 2015 6:01 pm
I don't think that did it... :cry:
Even tried completely removing the DDNS line
PostPosted: Sun Feb 22, 2015 6:23 pm
It's something related to your forum id.
Try this:
Go to User Control Panel->profile page and type "test" on the field Reef Angel Wifi Address
Click submit and let's see if that does it.
PostPosted: Sun Feb 22, 2015 6:52 pm
rimai wrote:It's something related to your forum id.
Try this:
Put in Test and it now comes up as my wifi address on the portal page. However it does not update the page...
PostPosted: Sun Feb 22, 2015 7:18 pm
I think it is working now :)
PreviousNext
Return to Portal
