Connection Status: Unreachable Address
Related to the Portal
nyknicks4412
Post by nyknicks4412 »
In the process of finishing the setup of my Reef Angel. I have run through the wizard and uploaded my code to the device. I have opened the necessary port on my router (2000), created a DMZ on my modem/router and can access my reef angel externally from my network. I have set DDNS on no-ip which is working.
However, I want to take advantage of the portal on here and setup a forum banner for my controller. I cannot seem to get the portal to receive data from my controller. It says my forum name and below it it says Connection Status: Unreachable Address.
Here is my code. Ideally I could get the DDNS provided by reef angel setup and get my controller updating the portal. Anything I am missing on why this isn't working would be much appreciated!
Port Assignment:
Port1 - Light1
Port2 - Light2
Port3 - Vortech MP10
Port4 - Heater
Port5 - Skimmer
Port6 - Reactor
Port7 - ATO
Port8 - Return
    ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port4Bit;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardLights( Port1,10,0,21,0 );
    ReefAngel.StandardLights( Port2,0,0,19,0 );
    ReefAngel.StandardHeater( Port4,780,790 );
    ReefAngel.Portal( "nyknicks4412" );
    ReefAngel.DDNS( "controller" );
Re: Connection Status: Unreachable Address
There is nothing wrong with the code.
I also don't see any data from your controller, which is weird.
The only thing I can think of is if the wifi attachment is somehow misconfigured, since you confirmed that you can connect from it remotely by using no-ip.
nyknicks4412
Here is the noip address you can see you can reach the controller....
nyknicks4412.ddns.net:2000
How would I trouble shoot the wifi attachment?
nyknicks4412
Roberto...this may help us troubleshoot. I am using a Mac and found that I was unable to connect to my wifi attachment using the files found through the download links on the site. After some searching on the forum I found that by downloading an older version of the wifi utility I was able to connect to the wifi attachment. Could this play a role in having issues connecting with the portal?
nyknicks4412
Digging some more and trying to throw all the information I can at you haha...
iPhone application works remotely. Using my cellphone network I am able to switch on and off ports on relay box. However, I go to the graphs section and am unable to get anything to display. Screen just shows blank.
More than likely because app asks for IP and I input the DDNS I created through no-ip...
I think we may need to use coolterm to identify the problem.
Connect the wifi attachment to the usb programming cable.
Connect at 57600 and type $$$ to enter command mode and type get e command.
Paste the result here.
nyknicks4412
Here is the output! Hope this helps. Thanks a lot for helping get this squared away
wifly-GSX Ver: 4.41 Build: r1057, Jan 17 2014 10:26:29 on RN-131
SSID=WiFly-GSX-b7
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=192.168.1.5:2000
NM=255.255.255.0
GW=192.168.1.1
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.1.1
Name=www.reefangel.com
Backup=rn.microchip.com
Lease=86400
FTP=198.175.253.161:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=DanKaylaApartment
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=*****
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.41>
I also don't see anything wrong with it :(
Just to answer on the phone app graph, it is generated from the portal database. If the portal doesn't have, your app won't have either.
Everything seems fine, but yet the portal doesn't update.
If you connect the controller to the usb programming cable and open coolterm at 57600 baud, does it print something every 5 minutes?
nyknicks4412
It actually is spitting out information...does the below look like what you'd expect?
GET /status/submitp.aspx?t1=662&t2=0&t3=0&ph=1057&id=nyknicks4412&em=0&em1=0&rem=0&bid=1&key=&ddns=controller&af=0&sf=0&atohigh=0&atolow=0&r=255&ron=0&roff=255
GET /status/submitp.aspx?t1=662&t2=0&t3=0&ph=1058&id=nyknicks4412&em=0&em1=0&rem=0&bid=1&key=&ddns=controller&af=0&sf=0&atohigh=0&atolow=0&r=255&ron=0&roff=255
Noticed some behavior I am not sure is normal or not. When I connect via coolterm I notice the controller screen goes blank for a minute and something on the relay box clicks and then it turns back on. Normal or?
Do you have a portal key configured?
nyknicks4412
I do not believe so...so I need to and how would I tell if I do?
Check the portal settings in the portal if it s on turn it off to test first. If that's the issue you need to change the line to ReefAngel.Portal("username", "key");
That is so strange.
Everything is correct, but I can't seem to understand what is going on here :(
Your portal should be populating.
Something weird I found out.
I still don't know why, but try this.
Change the DDNS keyword to something else and let me know if that works.
nyknicks4412
lnevo wrote:Check the portal settings in the portal if it s on turn it off to test first. If that's the issue you need to change the line to ReefAngel.Portal("username", "key");
Nope it is not on! Good thought though that would have been great if that was it. I just want this thing working so I can mount it on the tank
nyknicks4412
rimai wrote:Something weird I found out.
changed it to reeftank lets see if this is it! controller a reserved word?
nyknicks4412
I don't think that did it... :cry:
Even tried completely removing the DDNS line
It's something related to your forum id.
Try this:
Go to User Control Panel->profile page and type "test" on the field Reef Angel Wifi Address
Click submit and let's see if that does it.
nyknicks4412
rimai wrote:It's something related to your forum id.
Try this:
Put in Test and it now comes up as my wifi address on the portal page. However it does not update the page...
I think it is working now :)
nyknicks4412
rimai wrote:I think it is working now :)
Success! You must have worked some magic? Haha :D
http://forum.reefangel.com/status/banne ... s4412&t=-5
Any chance I can turn on the DDNS? I removed that line of code but would be bomb to not have to rely on no-ip.
Thanks a ton for the support on a Sunday. Wouldn't get that from a big box controller supplier.
nyknicks4412
Should I change my forum name...lol I think it doesn't like it
http://forum.reefangel.com/status/banne ... knicks4412 gets an ASP error page
It should work.
Put the line back and let us know.
The banner needs the labels. Go to the portal and set the labels.
shouldn't it fall back to the default values?
It should. I have to check why it is not.
nyknicks4412
rimai wrote:It should. I have to check why it is not.
That was the issue! I just had to hit save on the defaults and it took them and is now working...good stuff :D
[THUMBS UP SIGN]
