I went to re-calibrate it today after re-filling the ATO reservoir and I can't hit ok.
I can navigate all around get into the WL calibration, change it to WL1, but when I go to hit OK for the 0 level it doesn't register and switch over to the 100% level.
I can't hit cancel to get out of it either.
All the other calibrations (Salinity and pH) work fine.
The only way I can get out of the WL calibration is to hit Exit Mode from the Android App.
It happens on all the WL settings the stand alone or any of the Multi WL channels.
I have re-booted the RA and no difference.
I think the only code I added to my setup since the last time I did a WL calibration was the following...
//Flush RO/DI Membrane 3 times a week
ReefAngel.Relay.Set(Main_RODI,(now()+7200)%(SECS_PER_DAY*3)<300);Thanks for your help.
