after accidently doing a firm wear update on my wifi module it will no longer connect I get
** ERROR - Please disconnect and then reconnect the Reef Angel Wifi Attachment from the USB-TTL cable and try again.
I have tried using terra term with the following script
x=0
while x<>121
messagebox 'Start WiFly module configuration' 'Webscan Config Program'
;this macro all sent with 5 msec character delay
timeout=10
send '$$$'
wait 'CMD'
sendln 'factory RESET'
wait 'Set Factory Defaults'
sendln 'reboot'
wait '*READY*'
; Begin user settings
send '$$$'
wait 'CMD'
sendln 'set ftp address 198.175.253.161'
wait'AOK'
sendln 'save'
wait 'config'
sendln 'set wlan ssid ATT992'
wait 'AOK'
sendln 'set wlan pass 1181532401'
wait 'AOK'
sendln 'set option deviceid ReefAngelWifi'
wait 'AOK'
sendln 'set w j 1'
wait 'AOK'
sendln 'set c c 0'
wait 'AOK'
sendln 'set c r 0'
wait 'AOK'
sendln 'set c o 0'
wait 'AOK'
sendln 'set i d 1'
wait 'AOK'
sendln 'set c i 3'
wait 'AOK'
sendln 'set dns name www.reefangel.com'
wait 'AOK'
sendln 'set i h 198.171.134.6'
wait 'AOK'
sendln 'set i r 80'
wait 'AOK'
sendln 'set i f 0x06'
wait 'AOK'
sendln 'set s t 0x10'
wait 'AOK'
sendln 'set u m 2'
wait 'AOK'
sendln 'set i p 2'
wait 'AOK'
sendln 'set u b 9600'
wait 'AOK'
sendln 'set s p 0'
wait 'AOK'
sendln 'set c s 1420'Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM5
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM5
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM5
< CMD
> factory RESET
< factory RESET
< Set Factory Defaults
> reboot
< <4.41>
< reboot
Factory Settings Restored
wait 'AOK'
sendln 'save'
wait 'config'
sendln 'save user'
wait 'user'
sendln'reboot'
;inputbox 'Configure another module (y/n)' 'WiFly Config Program'
; convert inputstr to ASCII int value
; str2code x inputstr
endwhile
and nothing seamed to be fixing the issue please help
Wifi prob
Re: Wifi prob
You are not doing it correctly.
You must use teraterm to run that macro.
emict326
Re: Wifi prob
After reading of the Tera term help form I got it. Thanks
