I just finished installing my Reef Angel and I couldn't figure out why my pH never seemed to be above 6 no matter how many times I recalibrated it. I tried testing my pH in a cup of tank water and discovered it was reading 7.9, but in my tank it will read anywhere from 2.3 to mid 7's and fluctuate constantly. I discovered that when I turn my return pump off (a Mag Drive 7) my readings are normal +- 7.9, as soon as I turn on the Mag Drive it drops to around 5 (usually). I tested for current leakage in the water, my total current leakage is about 4 volts and the Mag Drive is only responsible for about 0.5-1 volt. I tried adding a grounding probe to see if it would correct the pH readings and it hasn't helped, but there is no measurable current in the water with the grounding probe.
I did purchase my Reef Angel second hand on Ebay (got an amazing deal on it). Today I ordered a Bulk Reef Supply lab grade pH probe before I realized that the drops coincided with turning my pump on. I previously thought the pH probe was just old and faulty...
Is there any chance that the amp load on the relay box is causing a problem with the pH readings? It doesn't seem to me like the small amount of current leaking from the Mag Drive should be the problem... however, I did just order a Jebao DCT 8000 to replace it with
