My RO Shut Off Mod
Talk about you and your tank/equipment
PostPosted: Wed Mar 18, 2015 4:49 pm
This is leak detector designed to go under the sink with an RO unit. I modified it to shut off on comand from one of the pwm ports.
The insides
Relay added
[imghttps://scontent-sjc.xx.fbcdn.net/hphotos-xfa1/v/t1.0-9/10277588_10152652610926861_5752335617534427298_n.jpg?oh=65fd6ebd82008164e271557ac01a1b0f&oe=557E1B78][/img]
Put back together with a connector for the pwm
Thank you Roberto for your help on the code
  // Low Float for RO water
     ReefAngel.PWM.SetDaylight(0);
     ReefAngel.PWM.SetDaylight(100);
    alert=true;
PostPosted: Thu Mar 19, 2015 5:28 am
Does it still detect leaks too?
PostPosted: Thu Mar 19, 2015 6:56 am
Yes. I wired the relay in parallel so the leak detector would still work. Eventually I am going to add a rope leak module to my setup.
PostPosted: Thu Mar 19, 2015 7:45 am
very nice.
Return to You and your tank
