Reef Angel doesn't see my water level sensor
leadguitarist05
My question seems like it would be easy... I have an expansion relay with an available usb port, I hooked my water level sensor up to it, rebooted the RA and tried to calibrate the water level sensor. The RA shows no readings for the water level sensor, as if it's not even there... Can I run the water level expansion off of the expansion relay, or do I need to buy the expansion usb hub for it to work...?
Re: Reef Angel doesn't see my water level sensor
The expansion relay box can only be used for outlets. You'll need to get the expansion hub.
leadguitarist05
Bummer... but I suspected that might be a limitation. Do I have to use the RA usb expansion? Or can I use any usb hub?lnevo wrote:The expansion relay box can only be used for outlets. You'll need to get the expansion hub.
leadguitarist05
Nevermind, I just looked, I already have an expansion hub... I just haven't hooked it up yet.leadguitarist05 wrote:Bummer... but I suspected that might be a limitation. Do I have to use the RA usb expansion? Or can I use any usb hub?lnevo wrote:The expansion relay box can only be used for outlets. You'll need to get the expansion hub.
It's not a usb hub. You need the expansion hub for anyone else asking the same question.
