Hi,
I was going to write some custom code for this, but I wanted to see if there is something standard for it already. If there is I haven't been able to find it.
I don't have any relays related to lighting. All of my lighting is controlled strictly from the 6 channel dimming expansion module (I use all 6 channels for Lighting).
I need the "LightsOn" override to turn these 6 dimming channels to some preset values, overriding what is being done by the normal code loop.
I can see how I could easily do this by checking for the override in my main loop, but I wondered if there was something built in for this.
Don
Lights On override and Dimmer expansion module
dedvalson
- Sacohen
Re: Lights On override and Dimmer expansion module
I'm not sure if there is or not, but it's something I will need too, so I'm following along to see what comes up.
This is only available for the standard channels. You will need to code for the dimming channels.
- joshlawless
Is there a way to check, in the code, whether the LightsOn mode is active?
Something like:
If ReefAngel.AreLightsOn() {ReefAngel.PWM.Set16ChannelRaw( 0, 4095)}
else {ReefAngel.PWM.Set16ChannelRaw( 0, PWMSmoothRampHighestRes( 7, 15, 22, 00, 0, 4095, 130, 0 ) );}
Something like:
- joshlawless
Looks like I found it (pasting here for posterity):
if (bitRead(ReefAngel.StatusFlags,LightsOnFlag))
