Temp probe 3pin Connector
ganjero
Post by ganjero »
Is the an easy way to fix/replace the Temp probe 3pin Connector? I just had a second one failed, the cable just came out of the connector after installing the RA in my new house. I am a very careful person, and after having one failed before I handle these connector very carefully.
Re: Temp probe 3pin Connector
If the wire came out, you can re-patch it or you can solder it to the connector.
ganjero
Post by ganjero »
What do you mean by repatch it? the cable came out but how do I get the metal pieces out?
You can buy those on your local electronics store or you can try pulling them out with a tweezers.
You can also use 3 pin computer fan connectors to replace them. Just make sure you go by pin position and not wire color when you do.
ganjero
Post by ganjero »
Thank you
