DIY Skimmate Locker on the Cheap
- cosmith71
Water jug from Walmart, float switch I had lying around, and a bit of carbon pad for stink control.
Re: DIY Skimmate Locker on the Cheap
I have similar thing.
Can I give you an advice?
Get a longer stem float switch or try to mount it a little lower into the container or maybe place the container inside a tub.
Not that it will happen, but I had it happen once to me.
My skimmer was dialed wrong and I was getting a lot of water going to the container. By the time the float sensed, there was enough water in the cup and inside the line to overflow the container.
I woke up 3 in the morning with my rope leak detector beeping
- cosmith71
Good idea. I hadn't thought of that.
jegillis
I use that container for my top off water, do not expect the top lid to be watertight mine was not...
- cosmith71
The big round one? I siliconed it on.
paperdesk
Nice! I've been working on building something like this, but I got stuck:
a. I want to use a two pin quick disconnect for the float switch. I have to look for this at a hardware or maybe auto parts store.
b. I also found my float switch stem to be too short. I haven't seen any with long stems, do they actually make such a thing?
- cosmith71
Yep. Lots of them.
http://www.chicagosensor.com/Extended-L ... tches.html
http://www.ebay.com/itm/LONG-Water-Leve ... 35a9e17a87
Yes, I have exactly same thing on my setup. Quick disconnect and long stem.
- cosmith71
I used those round barrel type DC connectors for mine.
paperdesk
paperdesk
I still haven't found a long stem float switch, but I've had one of these for a while, and if I silicone it in well it should do the trick. http://www.amazon.com/gp/product/B0076U ... UTF8&psc=1
- jsclownfish
nice. I've been wanting to put a reservoir signal in my top off water jug forever, but couldn't figure out how to get a long enough float towards the bottom of the reservoir. The silicone seal on the bottom makes me a bit nervous, but a tight seal with a layer of silicone should hold.
-Jon
-Jon
- jsclownfish
-Jon
-Jon
modulok
I have the same container, but I am using it horizontally and punched holes through the white cap.
I will post a picture later.
modulok
I haven't had to empty a full container yet, but I'm hoping to use the lever on the bottom.
Photo attached.
Sent from my A0001 using Tapatalk
Photo attached.
- cosmith71
Looks great!
