Adjustments using Controller
randynixon74
I'm having some trouble making adjustments using the controller menus and joystick. As I understand it, left and right change screens and up/down + joystick press makes changes. I'm not able to change anything. When I press the joystick in, I get the same menu list. Am I doing something wrong?
Randy Nixon
120g Acrylic Mixed Reef Tank
- Contact:
Re: Adjustments using Controller
what are you trying to change?
Sent from my Moto X
Sent from my Moto X
randynixon74
Really anything. It's like the menus are read-only. I was trying to change (override) the dimming settings initially, but then expanded to trying to change anything when that didn't work.
Randy Nixon
- cosmith71
When you push the joystick in you will get the menu of things you can change. You cannot change things on the status pages. They are informational only.
- Contact:
the values are really not changeable via the joystick. that functionality requires a lot of extra code on the controller and was just not feasible. it was much easier to handle value changing from the different apps instead.
randynixon74
Thanks, exactly what I needed to know.
Randy Nixon
