Are you noticing this error/problem after using the popup box to override the values?pandimus wrote:This error I'm having with the ai sol control is definitely on your end.. You have the dimmer control backwards on royal blue and blue.. I thought it might just be an indication problem, but they are indicating the same on my portal.
I did some further checking into the code and all I could come up with was me not updating the override values for the AI channels. This should not swap the values between Blue & Royal Blue. This would just cause the incorrect value to be displayed if the channel was being overridden.
I cannot find anything else in the code that would cause the 2 channels to be flipped. I parse the XML data and store the values based on the XML tag. I then pull the data out of my own local database using the exact tag that it was stored under. I have everything set as define statements to link to the proper values and use the define statements in my code.
I made my change and hopefully that will fix the problem you are seeing. If you could provide me with some feedback to my question I asked above, that would be helpful.
