Local Portal (i.e., local wifi page)
Related to the Portal
PostPosted: Sun May 03, 2015 4:54 pm
So I've got some questions about the page served up over the LAN by the Wifi module. When I go to http://192.168.1.250:2000/wifi, I see the fancier version of what is reproduced on the myreefangel.com portal, but there are some issues.
On the LAN page, I can only see the Relay expansion box, and not the main relay box.
I've added the water level expansion in my code, and expect to see a single water level data point, but the local (and, for that matter, remote) portal shows 5 channels of water level data (I only have the single water level expansion).
I see a section labeled "Ecotech Vortech" in addition to the section labeled "DC Pump" -- not sure why. No reference in my INO to Vortech.
Any input is much appreciated!
Here's my test code (not up and running yet):
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.AddORPExpansion();  // ORP Expansion Module
    ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit;
    ReefAngel.FeedingModePortsE[0] = Port4Bit;
    ReefAngel.WaterChangePortsE[0] = Port4Bit;
    ReefAngel.CustomLabels[0]="Heater1";
    ReefAngel.CustomLabels[1]="Heater2";
    ReefAngel.CustomLabels[2]="Skimmer";
    ReefAngel.CustomLabels[3]="Neck Wipe";
    ReefAngel.CustomLabels[4]="Refugium Light";
    ReefAngel.CustomLabels[5]="Filters";
    ReefAngel.CustomLabels[6]="Ozone";
    ReefAngel.CustomLabels[7]="Air Pump";
    ReefAngel.CustomLabels[8]="Circulation";
    ReefAngel.CustomLabels[9]="Diverter";
    ReefAngel.CustomLabels[10]="Kalk Stirrer";
    ReefAngel.CustomLabels[11]="ATO  Pump";
    ReefAngel.StandardHeater( Port1 );
    ReefAngel.StandardHeater( Port2 );
    ReefAngel.Relay.DelayedOn( Port3 );
    ReefAngel.DosingPumpRepeat1( Port4 );
    ReefAngel.MoonLights( Port5 );
    ReefAngel.DosingPumpRepeat2( Box1_Port3 );
    ReefAngel.WaterLevelATO( Box1_Port4 );
    if (ReefAngel.Params.ORP>450) ReefAngel.Relay.Off(Port7);
    if (ReefAngel.Params.ORP<400 && ReefAngel.Params.ORP>0) ReefAngel.Relay.On(Port7);
And here's a screenshot:
Screen Shot 2015-05-03 at 5.52.51 PM.png (195.34 KiB) Viewed 2677 times
PostPosted: Sun May 03, 2015 6:39 pm
And, on closer inspection, I note that the Relay expansion ports are labelled 11 through 18 (instead of, as one would expect, 9 through 16).
--edit--
Which is apparently consistent with the remote portal, and even how the unlabeled ports appear on the LCD of the controller unit.
PostPosted: Sun May 03, 2015 7:27 pm
Worth mentioning that the head unit LCD display only shows one water level channel (channel 0) when scrolling through the pages.
PostPosted: Sun May 03, 2015 7:51 pm
joshlawless wrote:And, on closer inspection, I note that the Relay expansion ports are labelled 11 through 18 (instead of, as one would expect, 9 through 16).
--edit--
the ports are labeled 1-8. the expansion relays start with 1 and go through 8.
for expansion relays, the first number tells you what relay and the second is the port number.
expansion 1 port 5 is 15
expansion 2 port 6 is 26
expansion 3 port 3 is 33
and so forth....
this keeps things consistent and easy going to identify. if you were to keep incrementing like you would expect, it would be much harder to determine what expansion and port was in use.
PostPosted: Sun May 03, 2015 7:58 pm
the lan page is still relatively experimental. it has been updated but is not as fully functional as the portal or smartphone apps. there has been issues with the way the scripts function on different browsers (i think it's written in javascript).
PostPosted: Mon May 04, 2015 3:28 pm
Glad to know it's not specific to my setup or my unit. I note that the Portal hosted here on reefangel.com also shows five channels for water level. Is this expected behavior, based on my code (in which I've got the line ReefAngel.AddWaterLevelExpansion(); )?
PostPosted: Mon May 04, 2015 4:59 pm
Yes, expected.
Return to Portal
