Longer data graphs than 7 days?
Related to the Portal
skehole
Post by skehole »
Is there a way to see data in the portal for longer periods of time than 7 days? I would like to see my ph over the course of, say, a month instead of just a week. Is that doable?
Re: Longer data graphs than 7 days?
skehole
Post by skehole »
Looks like a great service. Being kind of a noob though, I'm not quite clear what they're asking for in the application. Is it just the DNS info to link to the portal?
No, they'll need to query your controller, so you need to have some dynamic DNS. If you don't know how to set that up, there's an option to configure it right on the RA. I'm not up to speed on the process though. I'm sure others can chime in with it if you need help.
skehole
Post by skehole »
Got it all figured out. Just needed all the same info that I used to connect the UApp to my controller. Thanks!
