Can't upload any code :(
Junseld
I get the same error message every time I try to upload code. This is the error I get with trying to upload the initial internal memory:
Copyright (c) 2000-2005 Brian Dean,bdmicro/
Using Port : \\.\COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude done. Thank you.
avrdude: Recv:
- Contact:
Re: Can't upload any code :(
do you have a standard ra or ra plus?
if you don't know, then you can try the opposite one you selected in the wizard.
also, make sure the cable is connected to your controller before you try to upload. i know these are basic suggestions but can be overlooked.
Junseld
Binder, thank you for your reply and suggestions. I have already tried both troubleshooting steps but it still will not upload. Please share any other suggestions and thanks again.
Junseld
I bought it used and have never seen it work. The version is v1.1.0 Wifi WDT 1.
Junseld
When I try to restore preloaded code I get the following error message:
Dimming Signal
Date/Time Setup Menu
Standard Menu
Binary sketch size: 34,520 bytes (of a 30,720 byte maximum)
processing.app.debug.RunnerException: Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
at processing.app.Sketch.size(Sketch.java:1844)
at processing.app.Sketch.build(Sketch.java:1775)
at processing.app.Sketch.exportApplet(Sketch.java:1797)
at processing.app.Sketch.exportApplet(Sketch.java:1783)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2357)
at java.lang.Thread.run(Thread.java:619)
Dimming Signal
Standard Menu
Yes, but you still need to find out if it is a standard RA or a RA+.
This is the first step.
Ask the person you bought it from or open the head unit to check the board revision.
Junseld
I bought it from a LFS and I have no idea who he ordered it from. I am going to open it it right now. What should I look for? By the way, thanks for helping me.
Junseld
It says Reef Angel Main Unit 6.1 and there are three jumpers on the board to the right of the knob. A black jumper to the far left and the other two are white jumpers.
That's a standard RA and you will have a bit of a trouble fitting most codes without stripping it down to the bare minimum.
Make sure the serial port is correct and choose "Reef Angel w/ optiboot" as the option on Boards menu.
Junseld
I tried a usb port that I didn't think of using before and I was able to upload the code that I made from the wizard. I got error messages, probably due to the fact that it had to strip down the code to get it to fit, but everything is working perfectly now. How much would it cost to upgrade to a RA+ board? Thanks again for your help.
All you need is the RA+ board upgrade in the webstore
It's pretty simple to swap.
