Used ra unit
Maze531
Used ra unit
I am looking at a RA+ unit from a local person. Attached is his comment about the issue the unit has he states that ra will fix the issue. I was hoping I would get advice from you before purchasing the unit. I plan on using the ra to its full potential so I will soon after this purchase buy more expansions from here.
Thank you for the help.
Robert
- Contact:
Re: Used ra unit
it could either be a bad relay port or it could be how he has that port programmed. we have seen both types of issues here on the forum and further testing would be required to determine the exact cause. he is correct, roberto will fix it if it actually is a hardware problem.
that aside, that is a great price for a RA+. even if it's 1 port that has to be fixed, you can't beat the price for all the stuff you are getting. the RA+ alone is at least $269 or $289 depending on the type of model.
89delta
Re: Used ra unit
thats a killer deal
Maze531
Re: Used ra unit
So I picked this up. I down loaded the user manual and Arduino onto my PC I figured to start I would reset the programing back to intial memory. I am getting this any ideas? I have the usb connected just like in the manual.
Thank you for your help
Robert
Maze531
Re: Used ra unit
Ok nevermind please disreguard my last post. I was confused on the com ports I guess had to change it to com port 4 so was able to load it.
Robert
Maze531
Re: Used ra unit
I am trying to set up my wifi attachment
looks like it is getting stuck on trying to connect to router. It is also getting DHCP false. green light is flashing slow on the wifi attactment.
See attached picture.
Robert
Maze531
Re: Used ra unit
reading through other posts here are some more details
security settings and dhcp enabled.
Robert
- cosmith71
Re: Used ra unit
Slow green means it has connected.
You'll need to set the IP your router has assigned to static (DHCP Reservation on some routers) and forward port 2000 to that address.
Maze531
Re: Used ra unit
Wow I learned so much about computers that I didn't know last week with buying this lol thank you for your help.
Next question. This unit I bought has no power cords. The standard one for the RA unit easy to get already have one now the 12V power cords for the salinity and orb expansions can I pick something up at a local store for those or do I need to order them threw reef angel and if I do need to order them through reeef angel how do I do that?
Robert
Maze531
