Hi guys
I'm new to coding first of all. I have a 6 globe T5 lighting system. It has both morning/eve light day lights. I have the reef angel to turn on light according to time on port 2,3. I would like to have the ability to change the on/off time via the controller through a custom menu, with out the need to plug it back into a computer to change settings. Some guidance is needed please.
Thanks in advance.
T5 lighting control
Re: T5 lighting control
You can switch to using memory based code. Can you post your code and let us know the schedule you want each port. Do you have the wifi module? You can go visit the portal and look at the Internal Memory section for Time Schedule.
GreenVF
Yes i do have the wifi module. I have no real code only from the wizard.
- Contact:
then generate new code from the wizard and choose to store the values in memory. then you would use either the portal or one of the smart phone apps to be able to change the times easily. it's much harder to do via a menu...but could be done.GreenVF wrote:Yes i do have the wifi module. I have no real code only from the wizard.
the most flexible option is via the portal or one of the apps.
