ethernet serial port?
AlanM
Since the wifi attachment is really just a wifi serial port, would there be a way to get an ethernet serial port working with an FTDI adapter or something to attach to the multipin plug on the bottom of the RA+?
Re: ethernet serial port?
I'm not sure if it connects the same way, but the RA is compatible with an arduino ethernet shield...
AlanM
Ah, I see code in there for the Wiznet WIZ5100 in RA_Wifi.h. Bet that would work then.
