I noticed last night that mu WP-40 was not running properly, after switching cables and pumps around I think I determined it's a problem with the cable.
The pump was turning on for a split second and not making any wave.
I took the pump out and cleaned it (same issue).
I put a different pump on the Actinic channel (same issue)
I moved the cable and pump over to the Daylight channel (same issue)
I finally tried a different cable on both on my pumps and on both channels and it worked normally.
My question is what could be causing this?
Did a resistor or something burn out on the board?
This is a cable that I cut the header off of and was going to use with the dimming module, but then needed it in an emergency so I soldered the end back on and it's worked fine for several months now.
Jebao/Speedwave Cable issue
- Sacohen
- Sacohen
- Sacohen
Re: Jebao/Speedwave Cable issue
I don't see any damage.
The DC plug looks corroded.
It seems to be getting the proper power though.
I didn't take the heat shrink off though so I can't see if there's any damage on the board.
- Sacohen
I cut off the heat shrink and nothing on the board looks damaged.
I want to pull some readings off of the cable gong to the pump.
Which wires should I check?
The White/Green (Common) and the Blue (Ground)?
- Sacohen
I did some more examining and checking and noticed that one of the pins was loose and eventually came out.
