hi everyone,
i'm currently out of town, and wanted to clear the overheat on my tank.
However, for some weird reason, the app on my phone has sporadic issues connecting to my tank (authentication errors), so I can't use it to clear the overheat. It has connected maybe two or three times since I've been away, and hasn't been successful since.
Is there a way to clear overheat through the portal? Or any other way?
clear overheat?
Re: clear overheat?
Can you connect at all if you use the wan IP address?
You should get "Reef Angel Web Server"
