Hi,
I'm getting this error trying to upload code. The code is pretty much the same as last time, just changing the autofeeder times. I haven't uploaded new code in about 6 months. Everything's been working fine I just wanted to make a small change and upload the changed code. I'm not getting any compiling errors, just connection errors. I haven't updated anything since my last successful upload
Any advice is appreciated. Code is below. Thanks,
Todd
Watchdog Timer
Version Menu
Dimming Signal
Salinity Expansion Module
Wifi Attachment
Custom Main Screen
Relay Expansion Module
2014 Main Screen
Extra Font - Medium Size (8x8 pixels)
Number of Relay Expansion Modules: 1
Simple Menu
Binary sketch size: 55,798 bytes (of a 258,048 byte maximum)
Error rebooting when trying to upload code
martinresi
martinresi
Re: Error rebooting when trying to upload code
It worked. I kept restarting the arduino app and unplugging and replugging in the usb cable to the controller and eventually it uploaded. I think I remember something like this happening before. Am I missing some kind of step when i upload new code?
1. Unplug the existing color coded usb cable from the LCD RA controller.
2. Plug in the color coded usb cable that connects to the laptop into the LCD RA controller
3. Start Arduino and bring up the code
4. Plug the other end of the USB cable into the laptop
5. Upload code
5. Upload code
- cosmith71
Your COM port may be changing. I'd plug the cable into the laptop and then check the COM port before I fired up Arduino.
martinresi
Thanks Colin
