ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.StandardHeater( Port1,770,785 );
ReefAngel.StandardLights( Port3,8,0,21,0 );
ReefAngel.StandardLights( Port4,9,0,20,0 );
ReefAngel.WavemakerRandom( Port5,10,100 );
ReefAngel.Relay.Set( Port6, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.StandardLights( Port8,8,0,21,0 );
Does this code look correct
adrenalinejunkie
- Sacohen
Re: Does this code look correct
It looks correct to me.
What are you trying to do and what is not working correctly?
adrenalinejunkie
I'm having problems uploading a new code. A buddy of mine came over this weekend to help and said he thinks it had to do with my laptop have USB 3.0 instead of USB 2.0 I'm pretty confused with what he was saying /trying to explain
- Sacohen
Yeah. The code itself will not cause a problem uploading.
I believe USB 3.0 is backwards compatible, meaning it should work, but won't be as fast.
- Contact:
correct. usb 3 is backwards compatible with usb 2. it works just fine for me.Sacohen wrote:Yeah. The code itself will not cause a problem uploading.
Sent from my Moto X
