HI,
My RA is working perfecty, except the portal isn't showing my dimming module.
http://joaocdestro.dyndns.biz:2000/r99
____________
I have an Reef Angel purchased in 2012 with dimming signal module, The only change was the upgrade to RA to Plus a year ago (just the logical board)
I'm using the Reef Angel Wizzard to generate the codes and put "in memory", everything is working fine, the schedules, the dimming times, the manual commands/dimming from the iphone app, the portal acepts my manual imputs in memory changes...
I'm doing something wrong? my issue is just the portal
Portal don't show my PWM Dimm
- IMG_8638.JPG (103.42 KiB) Viewed 5062 times
- IMG_8637.JPG (98.29 KiB) Viewed 5062 times
- IMG_8639.JPG (59.33 KiB) Viewed 5062 times
Regards,
Joao C. Destro
Joao C. Destro
Re: Portal don't show my PWM Dimm
I don't know I i've done but now it's working! I just let the DDNS in Wizzard in blank
Thank-you Roberto.
Thank-you Roberto.
Regards,
Joao C. Destro
Joao C. Destro
