Hello,
Does anyone with good knowledge of HTML/AJAX programming want to be apart of the development of the internal memory settings change through wifi?
Curt has expressed that the "Updated XML data sending for Client Suite usage of reading/writing memory values" is in progress and I'm pretty sure that Dave is also apart of this one on his Client software.
But, I would also love to be able to have this capability with direct connection to the controller through wifi.
My idea is to have the internal webserver return a javascript file, which will then construct the webpage and everything necessary for the change of settings.
Everything has to be self contained in the JS file for it to work.
Then when the user changes any settings, an http request is made to the controller through wifi and the controller would change the internal memory and return with a sucess or failed response.
Let me know if you are this guy
Internal memory through wifi
Re: Internal memory through wifi
Do we have enough memory to hold the java script file somewhere? It seems to me that most systems are running on the very edge of having enough memory to run basic functionality. Mine is with 400 bytes of being maxed out and a javascript file to do what you describe would be several K.
yes. the wifi js file is hosted remotely.
The entire html page returned by the controller when you browse the controller is:
That's it.
The whole web experience is contained within the ra1.js file and that's why AJAX is really nice in this case.
<script language='javascript' src='http://www.reefangel.com/wifi/ra1.js'></script>
Can we have the possibility to host the js too?
Fresh Water Aquarium 180*60*80
Salt Water Aquarium 60*60*60
Click Here to see the Video of my Fresh Water Aquarium
Yes, but that would mean you would have to send all your webbanner stuff to your own server too.
ok
and can we host in the RA? Or whith an addon USB HD or other?
