Unreachable address
Ismaclst
Unreachable address
What would cause my portal to not update? It has been saying "unreachable address" for about a week now. It used to work fine until this started to happen. The wifi address that is shown on the portal page is the same one it has been using. If I lost power, shouldn't the portal automatically find the new wifi address?
Ismaclst
Re: Unreachable address
I had port forwarding working before. I can't even access it internally in my network.
That's what I mean.
Your router probably assigned a new ip address to your wifi attachment and port forwarding got messed up.
Ismaclst
I thought the portal was to suppose to automatically detect the wifi address of the wifi attachment? Right now it's still showing the one it was using when it was working correctly.
It will automatically find your WAN ip address.
The portal has no way of getting inside your network unless you allow it with port forwarding.
Ismaclst
I finally got to checking this out.rimai wrote:That's what I mean.
Have you test the port 2000?
Ismaclst
I did check it with that, and it says it's not open. I figured it was port forwarding, but I can't seem to see anything wrong with it. Nothing has changed other than I had to reserve the IP address again.
