So in January I turned off my Reef Angel and tore down my tank. I have since moved from NY to Florida and am starting up a small nano tank.
I just realized I do not have the same laptop that had my code files, so is the code still on the Reef Angel and how do I retrieve it ?
Is my code still there ?
- cosmith71
Re: Is my code still there ?
You can't retrieve it. You would need the original source files (on your laptop). I store all mine on my Onedrive so I don't loose it.
Did you happen to upload it here anywhere?
cjrudy
cosmith71 wrote:You can't retrieve it. You would need the original source files (on your laptop). I store all mine on my Onedrive so I don't loose it.
I am not sure , I would have to go back through all my posts
