So, I bought a few extra temp probes.
What all do I need to do to be able to see their parameters in either the screen, or the U-app?
And as far as joining them together; I basically just need to splice one probe into the wire of another, correct?
being that each is serialized.
More temp probes code
• Page 1 of 2 • 1, 2
how many probes do you have now? the controller supports 3 probes natively without any splicing.
Sent from my iPad mini |
5 is what's planned |
Yeah, splice them in parallel to each other and add this to your code:
We haven't found a way to look at them in the portal, correct? |
I found these online which should make it easy...
http://www.amazon.com/gp/product/B000E9ZQBU?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00 -Jon |
cool. But how do we see the temp of the other probes?
It depends on how you want to 'see' the temperature from the extra probes. Some options are on the LCD as a custom screen, on the portal as a custom variable, and or from internal memory as a wifi request.
-Jon |
Same splitter above but cheaper.
http://www.microcenter.com/product/2213 ... tter_Cable and even cheaper... http://www.microcenter.com/product/4493 ... ower_Cable and yet even cheaper if you aren't in a hurry. Free shipping too... http://www.microcenter.com/product/4493 ... ower_Cable Last edited by tkeracer619 on Sat Jan 06, 2018 12:41 am, edited 1 time in total.
I ordered one of these, will try to modify it to work. Hopefully it doesn't have too much circuitry.
Roberto, I can't find the post talking about using a resistor in the circuit when using a bunch of temp probes. If I am able to turn this hub into just a passive hub what type of resistor should I use and where would I place it? https://www.newegg.com/Product/Product. ... lsrc=aw.ds |
Users browsing this forum: No registered users and 7 guests
