More temp probes code
PostPosted: Thu Aug 13, 2015 12:55 pm
So, I bought a few extra temp probes.
What all do I need to do to be able to see their parameters in either the screen, or the U-app?
And as far as joining them together; I basically just need to splice one probe into the wire of another, correct?
being that each is serialized.
PostPosted: Thu Aug 13, 2015 3:55 pm
how many probes do you have now? the controller supports 3 probes natively without any splicing.
PostPosted: Thu Aug 13, 2015 6:11 pm
binder wrote:how many probes do you have now? the controller supports 3 probes natively without any splicing.
5 is what's planned
PostPosted: Thu Aug 13, 2015 9:32 pm
Yeah, splice them in parallel to each other and add this to your code:
  ReefAngel.AddExtraTempProbes();
PostPosted: Fri Aug 14, 2015 12:26 pm
rimai wrote:Yeah, splice them in parallel to each other and add this to your code:
We haven't found a way to look at them in the portal, correct?
PostPosted: Wed Aug 19, 2015 12:16 pm
I found these online which should make it easy...
http://www.amazon.com/gp/product/B000E9ZQBU?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
-Jon
PostPosted: Thu Aug 20, 2015 12:15 pm
cool. But how do we see the temp of the other probes?
PostPosted: Thu Aug 20, 2015 1:13 pm
It depends on how you want to 'see' the temperature from the extra probes. Some options are on the LCD as a custom screen, on the portal as a custom variable, and or from internal memory as a wifi request.
-Jon
PostPosted: Sat Jan 06, 2018 12:35 am
Same splitter above but cheaper.
http://www.microcenter.com/product/2213 ... tter_Cable
and even cheaper...
http://www.microcenter.com/product/4493 ... ower_Cable
and yet even cheaper if you aren't in a hurry. Free shipping too...
PostPosted: Sat Jan 06, 2018 12:36 am
I ordered one of these, will try to modify it to work. Hopefully it doesn't have too much circuitry.
Roberto, I can't find the post talking about using a resistor in the circuit when using a bunch of temp probes. If I am able to turn this hub into just a passive hub what type of resistor should I use and where would I place it?
https://www.newegg.com/Product/Product. ... lsrc=aw.ds
Next
Return to Addons
Users browsing this forum: moronta12 and 2 guests
