Lee's Feature Complete PDE
alexwbush
Re: Lee's Feature Complete PDE
Can you explain your memory use? How do you modify your memory? I assume you can from the RA memory in the app? Are they custom locations?
Yes. Custom locations. I use the direct http calls to modify them or a web page form I have created. The RA app does not currently have a way to change custom memory locations. I believe the android one does. I try to use memory rather than hardcoding so I can modify everything on the fly without recompiling. I've gone about a year or so without any major modifications thanks to this.
MDB1029
I didn't see it listed here so i thought i would ask, do you run any cloud and lightning code along with your sun location code? I am hoping to be able to incorporate both.
Not yet. The SunLocation is used to get the date/time for your main LED schedule. I haven't looked closely at the cloud/lightnign code yet, but I believe you still need to set manually your lighting schedule. The SunLocation class will set the schedule in Memory if you're using Internal Memory today.
I can no longer post my code. It's > 60,000 characters. I'm at 69k
- Sacohen
67504 characters, 5338 words, 1915 lines of code.
89delta
I use the sunclass in my code as well as cloud and lighting....not sure of the link but check out my code.MDB1029 wrote:I didn't see it listed here so i thought i would ask, do you run any cloud and lightning code along with your sun location code? I am hoping to be able to incorporate both.
Sent from my Samsung Galaxy Note 3
89delta
Lnevo,
How would I go about using your gap fill-in code for moonlights with my LEDs on the Daylight and actinic PWM outputs? My ver 2.1 code can be found on bottom of page....thanks for looking.
http://forum.reefangel.com/viewtopic.php?f=11&t=4731
89delta
I don't have them on ports. I use the moonphase coding on my actinic pwm channel.
I'm not sure I'm following.
My LEDs don't go below a certain effective %. After around 7% any lower there is no change in PAR or brightness and it is still pretty bright. I have my moonlights come on at 100% and ramp down to 0% to make up for that. I turn the moonlights on right before my main lights go off.
Since your moonlights are on the same channel as your LED there's nothing that can be "filled in"
Roberto, were you able to up the character count at all? Is it possible?
lnevo wrote:Roberto,
Ahhh.
Try again. Increased to 100K
If it doesn't work, I may need to reboot the forum app.
Ok the code is now up to date. It worked
A few bug fixes since July, especially on the third dosing pump.
ritz
Where did you post the code? The only one I could find was from 2013. I've been dying to steal some of your coding!
Thanks.
Thanks.
Its in the 2nd post. It may say its from 2013 but I edit it. It may say the time I edited in small print
Auto Water Change and Revamped mixing station.
MDB1029
I am having trouble finding all the code needed for your coral acclimation mode. Can you advise on how to implement this?
Which part do you want? The photoperiod or the dimming or both? Are you using SunLocation? Can you point me to your current code?
MDB1029
both photoperiod and dimming if possible. I don't use the sun location at this time because i have just never implemented it.
int DaylightPWMValue=0; // For cloud code
ReefAngel.FeedingModePorts = Port1Bit | Port4Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
ReefAngel.Relay.On( Port1 ); //return pump
ReefAngel.Relay.On( Port4 ); //skimmer
ReefAngel.StandardHeater( Port2 ); //heater 1
if ( ReefAngel.Params.Temp[T1_PROBE] < (InternalMemory.HeaterTempOn_read() - 10)) { ReefAngel.Relay.On(Port3); }; //heater 2 on
if ( ReefAngel.Params.Temp[T1_PROBE] > (InternalMemory.HeaterTempOff_read() - 5)) { ReefAngel.Relay.Off(Port3); }; //heater 2 off
ReefAngel.SingleATOLow( Port5 ); //ATO pump
DaylightPWMValue=PWMSlopeHighRes(10,00,20,0,0,55,60,0); //daylights
CheckCloud();
ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue);
ReefAngel.PWM.SetChannelRaw(0,PWMSlopeHighRes(9,00,21,00,0,50,90,0)); // Blues
ReefAngel.PWM.SetChannelRaw(2,PWMSlopeHighRes(9,30,20,30,0,55,60,0)); // spectrum
ReefAngel.StandardLights(Port6,18,0,10,0); // Fuge light from 1800 to 1000
if ( ReefAngel.PWM.GetChannelValueRaw(0) < 16 ||ReefAngel.PWM.GetChannelValue(0)>100)
ReefAngel.PWM.SetChannelRaw(0,16) ; //moonlight value
ReefAngel.DosingPumpRepeat1( Port7 ); //ALK doser
ReefAngel.DosingPumpRepeat2( Port8 ); //Cal doser
ReefAngel.Portal( "MDB1029" );
ReefAngel.DDNS( "Reef" ); // Your DDNS is MDB1029-Reef.myreefangel.com
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 33
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 14
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
// In this example, start cloud after noon
#define Start_Cloud_After NumMins(11,00)
#define End_Cloud_Before NumMins(19,00)
#define Lightning_Change_per_Cloud 50
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes
// of effects or unforseen result could happen.
// In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the
// 250 minutes (or 500 minutes) can fit in that 510 minutes window.
// Add Random Lightning modes
#define Calm 0 // No lightning
#define Slow 1 // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2 // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3 // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4 // Like Mega, but with more lightning
// Example: { Calm, Fast, Mega, Mega2 } to randomize all four modes.
// { Mega2 } for just Mega2. { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = {Mega,Calm,Fast};
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
static time_t DelayCounter=millis(); // Variable for lightning timing.
static int DelayTime=random(1000); // Variable for lightning timimg.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
randomSeed(millis()); // Seed the random number generator
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
if (chooseLightning)
chooseLightning=false;
switch (lightningMode)
case Calm:
break;
case Mega:
// Lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
// Send the trigger
Strike();
DelayCounter=millis(); // If we just had a round of flashes, then lets put in a longer delay
DelayTime=random(1000); // of up to a second for dramatic effect before we do another round.
break;
case Mega2:
// Higher lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
Strike();
break;
case Fast:
Strike();
break;
case Slow:
// Slow lightning for 5 seconds in the middle of the cloud. Suitable for slower ELN style drivers
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=4095;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
/*ReefAngel.LCD.Clear(255,0,120,132,132);
ReefAngel.LCD.DrawText(0,255,51,120,"00:00"); */
int x=0;
else x=17;
//ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart/60));
ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
else x=35;
//ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart%60));
ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
//ReefAngel.LCD.DrawText(0,255,90,120,cloudduration);
ReefAngel.CustomVar[7]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
else x=57;
//ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))/60));
ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
else x=75;
//ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
void Strike()
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
// Flash on
int newdata=4095;
Wire.beginTransmission(0x40); // Address of the dimming expansion module
Wire.write(0x8+(4*1)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 1.
Wire.write(newdata&0xff); // Send the data 8 bits at a time. This sends the LSB
Wire.write(newdata>>8); // This sends the MSB
Wire.endTransmission();
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
// Flash off. Return to baseline.
newdata=ReefAngel.PWM.GetChannelValueRaw(1); // Use the channel number you're flashing here
Wire.beginTransmission(0x40); // Same as above
delay(random(30,50)); // Wait from 30 to 49 ms
wdt_reset(); // Reset watchdog timer to avoid re-boots
cstart*=60;
cend*=60;
if (n>cend) return (int) PWMStart;
MDB1029
Sorry, I have another question for you as well.
I would really like to add the moon phases. My current moonlights run off my regular dimming channel 0 which is my main Actinic/Royal Blue channel with this code,
Would i be able to implement the moon phases off of this same channel?
ReefAngel.PWM.SetChannelRaw(0,16) ; //moonlight value-
MDB1029
I have my code posted here now http://forum.reefangel.com/viewtopic.php?f=11&t=5934lnevo wrote:Which part do you want? The photoperiod or the dimming or both? Are you using SunLocation? Can you point me to your current code?
Ok give me a little time and try to parse through your code and then see what we can do.
